Fuel tank removal?
Fuel tank removal?
I have a 2010 Tracker Bass Buggy 18 that came with a ridiculously large 42 gallon fuel tank. with a four stroke Mercury 40, it would take me a year to run out a full tank, not to mention the weight and how it must be slowing me down. I'd like to remove it and install a smaller tank but don't see any way to get it out without dropping the engine and tunnel completely off of the boat. Has anyone done anything like this or have any suggestions?
Re: Fuel tank removal?
I have the same toon but with a 60hp seems to me you could empty the main tank and use some portable tanks , maybe 2 six gallon tanks and mount them on the rear platform or maybe build a platform on the left rear. The other way is to not fill your tank up and use maybe 15/20 gallons of fuel.
Wayne and Carla Taylor
Vanvouver, WA.
2005 Suntracker Bass Buggy
54# Motorguide trolling motor
2 Hummingbird Fish Finders
03 Dodge Ram 1500 2wd
Vanvouver, WA.
I had also thought about emptying the tank and filling it with spray foam to add some buoyancy. My back rides really low in the water with that heavy four stroke on it. I found some smaller molded tanks I think would fit on top of the existing tank. Gonna measure this weekend. Has anyone used spray foam to add buoyancy?
Butch
Butch
(old) 2000 Sylvan 20' Tritoon
Unless your fuel tank currently sits in the water, and below the water line, you won't be adding any buoyancy. All you will be doing is adding the weight of foam, to an empty tank or space. I'd suggest just filling the tank with 10-15 gallons, and calling it good. The only problem I see here is that a fuel guage is not as accurate as one would like, but at least you would know that you could go a LONG ways on E.
"Nauti Weasel"
2005 Beachcomber Islander 26
GXPWeasel wrote:Unless your fuel tank currently sits in the water, and below the water line, you won't be adding any buoyancy. All you will be doing is adding the weight of foam, to an empty tank or space. .
I agree.
2019 Veranda 22 RFL 250SHO
Even if your tank is submerged, adding foam to it will not add one single iota of buoyancy. You've already displaced that much water. Adding foam will not displace any more...well other than the fact that you will add weight, and it will ride LOWER in the water.
If you trailer it all of the time, I would just put in enough to enjoy the day. If you leave it on the water, you will want to keep the tank full while it sits at the dock. An air gap will allow condensation to form inside and you don't want water in your gas.
Darin and Karri
Beaver lake Arkansas
That is my worry because I keep it at a marina. The tank rides at water level in the Suntrackers so I thought it might add some buoyancy. I guess my best option is an empty tank and add a smaller tank on the back deck.Darin wrote:If you trailer it all of the time, I would just put in enough to enjoy the day. If you leave it on the water, you will want to keep the tank full while it sits at the dock. An air gap will allow condensation to form inside and you don't want water in your gas.
Thanks for all the replies.
