Prop Help New SB522CR Continued
Keeping it simple, can some one get me the barrel diameter of an Enertia?
Not in Merc. specs.
Thks., jim.
Not in Merc. specs.
Thks., jim.
2012 South Bay 522CR 115-4S
2009 Dodge RAM Sport 2dr Short Bed 5.7L Black
Re: Prop Help New SB522CR Continued
What do you mean by "barrel"?
Carl & Suzi
150 Honda 15x15p Enertia prop
Power assisted steering
Denver, NC Lake Norman
Pleiku, Vietnam 1971
The center, tube, ? ? ? Gearcase diameter it fits?
I saw replies in other post of a few Enertia users. Can someone measure theirs?
Could any Enertia user please measure their gearcase diameter? OR their prop hub diameter? Please.
Traillblazer
I am running a Vengeance on my SB525. I am going to do a better comparison next week between the 15p of the stainless and my original 13 aluminum. You should be able to just look up the correct prop that you need for your motor. What are you trying to figure out?
I'ld be glad to, but what do you mean by barrel diameter? The hub or the actual inside diameter of the props "exhaust port"?
Just pulled it off to run one of the new protos Merc sent me, tomorrow. Let me know what you want measured.
Inside diameter of the prop exhaust port, at the front of the prop (towards lower unit) is 4 7/8". Its tapered from there to the back. Hope that helps!
Bryan
Bryan
I don't know why this is so hard. The outside diameter of the tube/barrel the blades attach too. I have combed many documents and is not mentioned at mercury anywhere. The hub is incorrect terminology because it is internal to the prop
barrel, or maybe body would be appropriate
__\
__ < THIS PART OUTSIDE
OR MEASURE YOUR GEAR CASE AND IS THE PROP SAME SIZE OR SMALLER. I.E. the gearcase of my 175XRi is 4 3/4",
but Trophy Plus is 4/1/4"
Thanks I hope, finally, also trying PowerTech RED3. Any experience?
__\
BEST prop for my boat. Just look up doesn't cut it. Not from Merc prop guide for sure.Traillblazer wrote:I am running a Vengeance on my SB525. I am going to do a better comparison next week between the 15p of the stainless and my original 13 aluminum. You should be able to just look up the correct prop that you need for your motor. What are you trying to figure out?
The outside diameter of the prop, towards the lower unit is 5 1/8". My Gearcase diameter is 5 1/4. its not so hard when you ask the correct question. There is no such thing as a tube or barrel. Its called an exhaust port. Its ok, you'll learn!
Oh, learning. bought this 1988 hull in 1990, first hung hopped Chrysler 115, After burning too many pistons, went
to a 175XRi in1991. Late upgrades are Bob's machine plate, SeaStar steering, Trophy Plus prop 26P. I just learned how to go 70mph, stone stock Livorsi GPS speedo.
- winner2.JPG (152.29 KiB) Viewed 2188 times
More learning
Marine Propeller Terminology
• Hub
Solid cylinder located at the center of the propeller.
Bored to accommodate the engine shaft.
Hub shapes include cylindrical, conical, radius, & barreled.
• Hub
Sweet boat! Had a 76 Checkmate with 150 Merc when I was a kid... Wish I still had it!
Prop is still off if you need me to measure anything else for you.
