Eek! Cheapo Underskinning...
Re: Eek! Cheapo Underskinning...
I underskinned my last pontoon with sign material. I went to a local sign shop and ordered 4'X10' sheets of aluminum it cut easy with hand held sheers and held up well. I was told the pressure of the water would wrinkle it, I put screws every 6" and the underskinning looked as good after a season of use as the day I put it in. And the sign material was a whole lot cheaper than the quotes I was getting from the metal shops for thicker stuff.
2013 South Bay 442CR STT
150 HP Mercury 4 Stroke
Lets not be so subjective...Im sure someone knows the real thickness if the stuff sold for underskinning?
Mark
Rush Lake, Atlanta, MI
- Ron Burgundy
It's sorta thick a little bit, but not really.guy48065 wrote:Lets not be so subjective...Im sure someone knows the real thickness if the stuff sold for underskinning?
It's all good then. Buy whatever's cheapest.
Mark
What I used:
Amerimax Home Products 68124 Aluminum Roll Valley Standard Flashing
Ordered it from Amazon.com
50' X 24" roll. .014 thickness
Price: $78.78
Price: $78.78
I used .063. Seems to match the thickness of what Southbay puts on at the factory. It was just under 300 for materials.
BobG I would also like to see some photo's when you get them.
Since there is no water in the lakes in my immediate location (down over 80+ feet) it would be a great time to tackle projects.
I look forward to seeing the pictures when you get them.
Thanks Bud!
Thanks Bud!
- Medina Lake, Texas - Water use to be up by the tree line.
- Lake_2.JPG (20 KiB) Viewed 2959 times
- Medina Lake, Texas - Has actually dropped since photo was taken, where you see water in the photo, it's all gone.
- Lake_1.JPG (22.36 KiB) Viewed 2958 times
DinoSteel
2007 Bentley 200 Cruise
50 ELPT EFI BF
50 ELPT EFI BF
Has anyone tried .090" FRP (fiberglass reinforced plastic) panels? Can't be bent into a 90 but most DIY underskin projects I've seen all use flat sheets & strips anyways. Thinking thicker, cheaper, quieter...
Mark
I used polyethylene pile wrap, with stainless fender washers.....has held up great for 2 summers now. only 1 screw came lose, in the back, fixing that today.
Husband of the Captain of "Pitt Crew"
2006 Suntracker Regency Hut
Hard Water, Soft Water, Hell I guess you never heard of Culligan water softner. Ask your wife the difference or move to the country and live with well water.
2001 Mercury 90 HP (sold)
Elm Grove, La
Lake Bistineau
Elm Grove, La
Lake Bistineau
- evinrude2stroke
What kind of screws did you use?..... Self tappers? I may add this to my list of fall projects once the boat is out of the water.bruuuuce wrote:I underskinned my last pontoon with sign material. I went to a local sign shop and ordered 4'X10' sheets of aluminum it cut easy with hand held sheers and held up well. I was told the pressure of the water would wrinkle it, I put screws every 6" and the underskinning looked as good after a season of use as the day I put it in. And the sign material was a whole lot cheaper than the quotes I was getting from the metal shops for thicker stuff.
Dave
yep, self taping....ended up predrilling anyway though....was just easier.
- evinrude2stroke
Thanks for the rely. One more question...Did you under skin every exposed area? Or did you leave a space on each side my the pontoons for breathing? I'm concerned about the wood getting wet from up top and not drying adequately underneath resulting in premature rot...jepperson wrote:yep, self taping....ended up predrilling anyway though....was just easier.
Dave
