Brass, copper, anything BUT aluminum, stainless or plastic plugs will contribute to severe corrosion.
How to fix pitting on your logs.
Re: How to fix pitting on your logs.
Garnet. Make sure if you bottom paint DO NOT use paint containing copper. Ask Ron about that episode, lol.
- emerald_coast_tooner
Well, finally got to drain the logs. Starboard side no water. Port side had a little in the cone but the middle section took a few hours through the 1/8" hole I drilled. Got all plastic plugs too. Marine TeX and ss pan head screws complete the frankentoon look today. We'll be on the water this weekend!
"One Love"
1997 Grumman 24 FS
1996 Evinrude 88
1997 Grumman 24 FS
1996 Evinrude 88
All the corrosion has been sand blasted. Ready for acetone and marine tex gray. Sorry to be slack on the pics.
"One Love"
1997 Grumman 24 FS
1996 Evinrude 88
1997 Grumman 24 FS
1996 Evinrude 88
- Ron Burgundy
Pics or it didn't happen. No excuses!
Now time to clean and apply marine tex. I tried to get all the angles I could with the spot blaster. Man, I love that thing...takes barnicles, old paint and corrosioon off like nothing.
- IMG_20130815_073126.jpg (692.31 KiB) Viewed 9442 times
"One Love"
1997 Grumman 24 FS
1996 Evinrude 88
1997 Grumman 24 FS
1996 Evinrude 88
wow that is ugly!!!
They look clean as hell though! Good luck getting them sealed!
+1! My face didn't even look that bad when I was a teencurtiscapk wrote:wow that is ugly!!!
Hopefully you can solve the original problem that created this mess in the first place.
Good luck to ya. The MarineTex is great stuff.
I am not a metalurgist like BMR but can you fill the pits with lead solder and sand it before painting? I do not know if the solder will stick with the aluminum but someone else will chine in.
Man that sucks, good luck with the repairs.
margaritaman wrote:I am not a metalurgist like BMR but can you fill the pits with lead solder and sand it before painting? I do not know if the solder will stick with the aluminum but someone else will chine in.
I went with marine_tex because I can get back on the water before further sealing with interlux 2000e and a few coats of trilux 33.
- IMG_20130815_153625.jpg (534.12 KiB) Viewed 9398 times
"One Love"
1997 Grumman 24 FS
1996 Evinrude 88
1997 Grumman 24 FS
1996 Evinrude 88
Sorry for the poster size pics from my phone. Whoa!
"One Love"
1997 Grumman 24 FS
1996 Evinrude 88
1997 Grumman 24 FS
1996 Evinrude 88
- Ron Burgundy
Looks good. I see that stuff in my future too.
Well its sealed up. Its ugly but it will float now.
"One Love"
1997 Grumman 24 FS
1996 Evinrude 88
1997 Grumman 24 FS
1996 Evinrude 88
I always thought GregF was the metallurgist ??curtiscapk wrote:margaritaman wrote:I am not a metalurgist like BMR but can you fill the pits with lead solder and sand it before painting? I do not know if the solder will stick with the aluminum but someone else will chine in.
