Livewell/Icebox
Ron Burgundy
Livewell/Icebox
#1 Post by Ron Burgundy » Wed Sep 25, 2013 7:11 am
I'm thinking about insulation my livewell and adding a lid so the water doesn't slosh out. I mostly fish with artificials so I don't utilize it for bait often. I would like to use it for keeping the fish iced. It one of those seats with a livewell under it. Anyone else done this conversion?
Re: Livewell/Icebox
#2 Post by curtiscapk » Wed Sep 25, 2013 8:09 am
Hey Brett! Where you been?
How about a pic of how it is now? If it is like my old one it had a oval shaped black plastic insert inside of the seat. I would assume you could put some styrofoam around the outside and a cut a groove in a piece of styrofoam to set on the insert for a lid.
I which I had a pic of mine to show you what I mean but that baby is just a parts bin now.
MH Hawker
Re: Livewell/Icebox
#3 Post by MH Hawker » Wed Sep 25, 2013 10:00 am
When I built my live well I put the blue insulation on the sides and bottom just so I could also toss in a bag or two of ice and use it as a cooler, its worked out fine. Mine isnt used as a seat though.
Ron Burgundy
Re: Livewell/Icebox
#4 Post by Ron Burgundy » Wed Sep 25, 2013 12:48 pm
It's like this one. The seat flips up and the livewell is under it.
Ron Burgundy
Re: Livewell/Icebox
#5 Post by Ron Burgundy » Thu Sep 26, 2013 5:26 am
curtiscapk wrote:Hey Brett! Where you been?
Wassup Curtis, i've been checking in once in a while just not much going on lately.
Your setup sounds like what I want to do. I'm trying to find some aerosol spray foam insulation to coat the bait well and them fabricate some type of insulated lid to go under the seat. I just want to be able to keep ice on the boat for a few hours without lugging around a big cooler.
Re: Livewell/Icebox
#6 Post by curtiscapk » Thu Sep 26, 2013 7:17 am
I was thinking gluing styrofoam on the bottom and sides and then under the seat base. I would think it would be farely easy. You might have to cover the styrofoam with FRP or something similar so the fish stink doesn't soak into the foam. It would also keep the foam from getting dinged and falling apart.
Man I am good! Just found these.
http://www.bbcboards.net/bassboat-resto ... ooler.html
http://www.tidalfish.com/forums/showthr ... r-question
:alright :alright
fastbackford
Re: Livewell/Icebox
#7 Post by fastbackford » Fri Sep 27, 2013 5:31 am
I'd try using a couple layers of cork sheeting for the insulation instead of the styrofoam.
Government Warning:
Governments are extremely dangerous.
Death, imprisonment, theft of property
and loss of freedom will result from
giving them too much power.
lightpants
Re: Livewell/Icebox
#8 Post by lightpants » Fri Sep 27, 2013 12:46 pm
I would think the expandable foam insulation would do a good job at insulating the live well.
SoCalAngler
Re: Livewell/Icebox
#9 Post by SoCalAngler » Sat Oct 12, 2013 4:08 pm
Ron, not about your livewell, but I do have a question about your pontoon use in salt water (if used in salt water).
I have noticed in your posts (cool pics BTW!) that you fish in Florida. Do you fish in salt or fresh water? If salt, how does your boat and trailer hold up as far as corrosion? I know salt wreaks havoc on boats, motors, and trailers. I'd love to take mine out to the salt water here in So Cal (San Diego Bay, LA Harbor, Long Beach Harbor) but am very concerned about corrosion in my engine, boat, toons, trailer, etc....
Thoughts?
Thanks!
2011 Keystone Outback 250RS
Ron Burgundy
Re: Livewell/Icebox
#10 Post by Ron Burgundy » Sun Oct 13, 2013 4:09 pm
SoCalAngler wrote:Ron, not about your livewell, but I do have a question about your pontoon use in salt water (if used in salt water).
Thoughts?
Thanks!
Thanks. I fish and boat exclusively in saltwater along with thousands of other boaters. Saltwater is really not the kiss of death some would lead you to believe. A good washdown after every trip and you'll be fine. Also you need to flush the motor with freshwater after every salt water trip. Lots of good sandbass just south of the Coronado bridge. Used to kill it drifting over the channel.
Does your trailer have carpeted bunks with pt wood?
