Trim motor very sluggish -- What am I looking at?
Noticed earlier this season that my trim motor was having some difficulty raising my 90hp. Today as I was closing the boat down for the season I could hardly get it to raise. How much am I looking at to replace the motor....I'm not even sure that's the problem, but I figured it was. How difficult are those to replace?
"If 10% is good enough for God, then 9% should be just fine for the Federal Government"
Herman Cain - Aug 18 2011
1997 90hp 2 Stroke Merc
1997 Sun Tracker Fishin' Barge 21
Re: Trim motor very sluggish -- What am I looking at?
Have you checked the hydraulic fluid on the tilt and trim?
Also, check your battery and all connections. I had a bad connection one time which caused the exact problem you are describing...
Good Luck!
Dan
Good Luck!
Dan
Thanks for those suggestions. I have not checked the hydraulic fluid. Also, I added a 3 battery charger so the idea that I have hooked something back up wrong is a real possibility too. Thanks
check fluid level, add as needed and run it up and down a few times to self-bleed. Replace the motor and/or pump as a last resort.
playcat
JC 266 TriToon
Kerr Reservoir, VA
JC 266 TriToon
Kerr Reservoir, VA
