Ferg's Winter Project
Mrtoler
Re: Ferg's Winter Project
#46 Post by Mrtoler » Sat Dec 28, 2013 11:28 pm
What helm have you decided on? Or is that not decided yet?
2006 dodge ram quad cab
Crosby Texas
fergusmj
#47 Post by fergusmj » Sun Dec 29, 2013 3:29 pm
95% sure we've decided on the RTM 41" stand from pontoonspecialists.com
http://www.pontoonspecialists.com/p-313 ... nsole.aspx
While it is big, we like a lot of the features on it and it seems like it will look more "built for" as opposed to an "add on" as some of the others. Having the bigger console is going to make me eliminate the lounge back behind the captain chair, but that's not too big of a concern. It'll save me some $ anyway. A front cupholder may have had an impact on the decision :beerthought :drink
Ferg's Tritoon Build
#48 Post by curtiscapk » Mon Dec 30, 2013 8:25 am
Ferg,
not sure if you could get them to ship it but check this console out.
http://kansascity.craigslist.org/boa/4264571308.html
Looks brand new. :donno
HoosierTOON
#49 Post by HoosierTOON » Tue Dec 31, 2013 1:37 pm
Also - I know you mentioned not liking the wood grain in those panels for the PS console. You should look into hydrographics. On a piece that small it would be pretty inexpensive and you can choose from hundreds of designs (carbon fiber, metals, camo, wood grain, dollar bills, skulls) I have re-done most of the interior plastic pieces in several of my cars using this method and it holds up great. Not sure where you are located but I have used Liquid Imaging here in Elkhart, IN and Rev Dynamics in Plymouth, IN both with great success.
David
ToonGuy
#50 Post by ToonGuy » Thu Jan 02, 2014 7:47 am
fergusmj wrote:I do have fence risers, however, the bolts I have are not long enough to use with them :(
The bolts are a type that slide into the bottom of the track of the fencing, so it's not just a normal bolt. Otherwise I would. The bottom of the fencing is a little bit off of the floor though as the fencing bottom has some spots that lift it up a tad. The other nice thing is that the fending is installed on the rub rail and not the actual carpet itself
Hold up here...those bolts should be 2" long, plenty long for risers. I've installed the PontoonStuff 3/8" riser with no problem. Can you double check the bolt length?
fergusmj
#51 Post by fergusmj » Thu Jan 02, 2014 8:23 am
Sure thing. I'll check when I get back out to the barn in the next week or so. Right now we have 5" of snow and it's too cold :scared
Maybe with it being such a thick carpet? That stuff is thick.
I will say, I at first started with trying to bolt through the cross members as well, so I'm adding some thickness to those sections. I think even without that though, it seems to be a bit short.
fergusmj
#52 Post by fergusmj » Thu Jan 02, 2014 5:01 pm
For those of you who have experience with new furniture. Based on the pictures that i've found, the gas cap should be above the 11" high aluminum fence rail piece. I don't believe the gas cap would fit below that without potentially causing issues. Based on the dimensions of the corner seat, I may have to cut into the back of the seat since the base is 12" high and the fuel fill will be about 12 or 13". Can anyone confirm that this is the standard procedure for this? I saw the one build where Ty ran his fuel fill into the lounge back, but the fuel line comes up right into the corner seat, so I'd rather not have to run a fuel fill hose through a lounge back, bench seat and corner bench. I was hoping to just be able to cut into the base, without getting to the back rest part, but I don't think that will be the case.
Pic 1 shows my layout. You can see the fuel lines coming up from underneath the deck
Pic 2 shows the exterior of the same model fencing that I have and where the gas cap is (not mine, pulled from the net)
Pic 3 shows that the gas cap would be above the 11" piece of fencing (12 or 13" probably)
Pics 4, 5 and 6 are the corner piece pictures
Here is the link for the fuel fill cap
http://www.go2marine.com/product/207743 ... ngled.html
Mrtoler
#53 Post by Mrtoler » Thu Jan 02, 2014 9:12 pm
It's hard to say how it will work out until you have the seat sitting there, there isn't anything wrong with running a gas line through there or notching out the base, it's just whatever it takes to make it work.. Might also try backtoboating.com for a good selection on gas caps... Ezacdc.com is another good part site just FYI :coffee
Crosby Texas
Bamby
#54 Post by Bamby » Fri Jan 03, 2014 5:17 am
On mine I used this unit: Perko, Combination Gas Fill & Tank Vent and lift a hatch to access and fill. On yours you may rig it up where you lift a cushion to fuel. You would still need to vent the seats in the back but that should be inconspicuous and easily done. A small spill bucket would also be a nice additional feature should you decide to go this direction.
ToonGuy
#55 Post by ToonGuy » Fri Jan 03, 2014 6:39 am
You're going to be tied more to what fill you use and where it will fit on the fence. Look at this build I did, the fill goes in to the DeckMate base which is 12" high. It makes a 90 deg. turn and angles down to the tank. It fills fine, by can or pump. I get my fuel fills from BackToBoating.
fergusmj
#56 Post by fergusmj » Fri Jan 03, 2014 6:57 am
Thanks guys. I appreciate all of the help and input and reassurance on these questions.
fergusmj
#57 Post by fergusmj » Sun Jan 05, 2014 1:59 pm
Got some goodies from the the local South Bay dealer. I ordered through them since the cutouts were already done on the fencing. I wanted to get the OEM lights that were used. don't mind the dog
You can see the cutouts already done here
fergusmj
#58 Post by fergusmj » Sat Jan 11, 2014 1:36 pm
got my new helm today
#59 Post by curtiscapk » Sat Jan 11, 2014 4:04 pm
nice what did you get that for?
fergusmj
#60 Post by fergusmj » Sun Jan 12, 2014 3:51 pm
curtiscapk wrote:nice what did you get that for?
$750.
Once I started adding the value of everything on it, I feel it was a decent value.
helm: $300 value
gauges: $200 value
switches: $120 value
Tilt helm setup: $200 value
Steering wheel: $60 value
Also, that fact that it matches the setup that I want dimensionally is the main reason we were wanting it. Wired gauges is always nice too :biggrin2
