2000 Suncruiser Trinidad 204 Rebuild
- TonyTwoToons
This is my rebuild. My oldest gaughter was invaluable during the process as was my neighbor's son who helped tear out the carpet. My father-in-law left her out in the Florida sun without her cover most of the time. Structurally she was solid, undented toons, good deck, sound trailer, but everything else had to go.
Here's the Chief enjoying the ride:
Here's why she enjoys the ride:
Cheers,
Tony
Tony
Glad to be here, proud to serve.
2000 20' Suncruiser Trinidad 204 w/ 1999 70HP Evinrude 4 Stroke
Cruisin' The Red River in Shreveport/Bossier City, Louisiana
Re: 2000 Suncruiser Trinidad 204 Rebuild
Nice job !
Been there done that, great job , now have a toon you built !!!
maybe I'll get our radio put in, we were to busy using it to miss the radio
Great job! For some reason I love the color!!
- TonyTwoToons
I usually went out with a wake boarding buddy and he brought the tunes. This spring I'm adding a second battery and the radio. I have to direct the sound on the deck and behind the boat when we're beached. I don't have much room to work with because of the layout. I've got to be creative.HandymanHerb wrote:Been there done that, great job , now have a toon you built !!!
Cheers,
Tony
What a transformation!! you did a great job!!!
Wow! Great job, looks pretty damn good!
90 Mercury Fourstroke
pond tuuunes
Wow! Nice job, looks great. JT
Great job on the rebuild!
- TonyTwoToons
So, I've got this unsupported seat back. I'm a little concerned that my guests will lean back and end up laying on the deck. I'm thinking a couple pieces of 1" square aluminum tubes bolted to the seat bottom with some backing plates inside the seat base. I plan on putting them as far out on the edge as I can and as high up the seat back as possible to hit the frame of the seat back. Should I be concerned that the base won't be able to support the load? There's not much load to carry but enough to concern me. Maybe I'll put three posts. Anyone got better ideas?
- IMG_20140309_205130_1394416442623_1_1394416470450_1.JPG (137.87 KiB) Viewed 9754 times
I don't see why what you are suggesting would not work. If having that space open behind the seat is important, then I would think your idea is the best solution. If you do not need that space to remain open, then another suggestion might be to build some kind of storage box for that space (for a cooler, life vests, ropes, fenders, live well, fishing stuff, etc -- all depending on how you use the boat). It could serve as dedicated storage while supporting the back of that seat as well.
Nice job rebuilding, by the way.
2007 South Bay 925 Tri-toon
5.7 Volvo I/O
5.7 Volvo I/O
- The_Hellbilly
Good place to put a large storage box, cooler, or custom designed a ski tow
2005 Voyager 22ft Tritoon
2004 Honda 135hp
2004 Honda 135hp
We have basically the same layout on our 2003 Trinidad - we have that same fishing seat on top of the fuel area. That seat rarely gets used and I've thought about making a sunpad for that area so it could still be used for storage underneath. You could do the same thing and that would support the bench in front of it as well.
