GPS options
GPS options
My current boat has a Humminbird GPS / locator built into the dash. I run a Navionics card for better navigating my lake , the problem is the screen size. I cant see chit unless I drop my cheaters down to read the lines.Sucks getting old. I would like to use that one for depth and bottom contours and get a gimbal mounted larger screen dedicated GPS only that will accept a nav card. Is there an option or are you stuck buying a bigger combo unit and not getting the transducer ?
Re: GPS options
Navionics makes a nice app for the Ipad. That would give you the bigger screen so you might not need the cheaters. I just keep the cheaters on the helm to use with my small Humminbird combo since I have the exact same issue as you.
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
Lake Conroe, Texas
2006 Yamaha F225
Re: GPS options
I'm using a ipad Air 10 (9.7) inch screen and a Navionics ap. I'm 73 and need a big screen for my old eyes. I've mounted the ipad in a mount that fits into a cup holder to the right of the wheel. This has worked excellent!
The Bimini must be up to read the ipad in the bright FL sun. I also have a Satellite Weather ap that gives real time movement of any storms in the area. This requires a Verison monthly fee ($20). The GPS does not require a fee if you buy a ipad that is GPS enabled.
I have a small (3.5) in dash Humminbird for my depth readings now. I will be replacing this in a few months with a 7" side/down scan fish finder machine that via wifi will send its picture to the larger ipad.
Kind regards,
Rascal
Kind regards,
Rascal
Fishing Year Round SW Florida
Premier 22' 2012 Cast A Way
115 hp Honda, 15.5 x 13 prop
Sea Star Power Steering
Day Enclosure
Loan Star Anchor Winch
Fixed Mount ipad Air for
Day Enclosure
Re: GPS options
Hmmm , may be a great option . Wife has the I pad . What do you have to buy ? The app is free but you have to purchase a lake download ??
Re: GPS options
Yes, you have to buy a navigation ap. There are several, Garmin and Navionics seem to be the most popular. I paid $50 for the Navionics. I like it a lot.... You down load it like any ap on to the wife's ipad. You also need a way to mount the Ipad to your boat.
I got most of my ipad boating use information from experienced boaters on the "THT" (The Hull Truth) boating forum. Use the "search" system there, input "ipad". You'll get plenty of posts regarding ipad's. If your wife has a ipad that does not have the "GPS" feature it will not work. Unless you buy a plug in GPS for the ipad. They are about $50 to $100 on Amazon. If she has it.... you've lucked out.
Kind regards,
Rascal
Kind regards,
Rascal
Day Enclosure
Day Enclosure
- brianD
- Location: Live in STL, Boat wherever there's enough water to not mess up a prop.
Re: GPS options
I solved this problem quite cheaply. I have sunglasses with Cheaters built in... makes it easy to see the GPS...
b
2006 Landau Excalibur 2700
225 Suzuki 4 stroke
2011 Bear tandem trailer
2011 3/4 ton Suburban
225 Suzuki 4 stroke
Re: GPS options
What ever happened to the good old days?
Maps, study skills, and some Christopher Columbus attitude!
Re: GPS options
That's what I use also, not only to see but to keep the wind out of my eyes. With contact lens, the wind is a pain in the azz.brianD wrote:I solved this problem quite cheaply. I have sunglasses with Cheaters built in... makes it easy to see the GPS...
36 mph gps...
Cherokee Lake, Tennessee
U.S. Navy 1971-1977
36 mph gps...
U.S. Navy 1971-1977
