Thanks Ryan! It's getting closer!
r&s20 wrote:i like that prop guard you have on there.
but
I always cover my lower unit with a bucket in the winter! I broke this one in the fall when I put it on. I just replaced the transom and use the transom saver every time especially over winter!
curtiscapk wrote: I just replaced the transom and use the transom saver every time especially over winter!
Hey Craig. Seems like I read somewhere that one is supposed to winter a motor in the vertical position in order to properly let condensation out and avoid any chance of freezing. Not 100 percent sure on that one, but it might be worth a second opinion from someone.
I know that my I/O is mandatory to store in down position to keep critters away from seals and bellows.
I have heard that as well, but with the old transom it made a huge difference if the saver was on there or not. The flex was insane. Granted this new transom may be ok to handle it, but I haven't had any issues of freezing in 4 winters so I still do it this way I just make sure it is covered well to keep out any moisture. I am pretty sure it can still bet some air flow as well. IF I am wrong it will be expensive and I will have a definite answer on the subject....
Totally agree on transom savers when trailering. I always used one, especially on larger motors.curtiscapk wrote:I have heard that as well, but with the old transom it made a huge difference if the saver was on there or not. The flex was insane. Granted this new transom may be ok to handle it, but I haven't had any issues of freezing in 4 winters so I still do it this way I just make sure it is covered well to keep out any moisture. I am pretty sure it can still bet some air flow as well. IF I am wrong it will be expensive and I will have a definite answer on the subject....![]()
The moisture I am referring to is condensation during storage, which your ultra-fancy rain deflector can't protect you from, although it might save you from a bear attack
Just trying to save you from making a long rebuild thread even longer.
I know you are I may start keeping it down. If it isn't too late.....
Now you have me all freaked out... even after doing it the same way since 08...... Damn you Todd!
After years of doing it, methinks you'll be just fine. I have good vibes. Your summer will be epiccurtiscapk wrote:Now you have me all freaked out... even after doing it the same way since 08...... Damn you Todd!
Apologies for bringing it up. Freaking people out, my specialty.
Heading down tomorrow to get THE FLOATER water ready! Load up all my vest, noodles, CUPHOLDERS!, etc. Still need to tighten everything up, mount the ski tow bar and make sure she starts up!
Pics to follow!
Pics to follow!
Dangit Craig. Are you gonna stick me with the 'Latest Launch Trophy' this year?
I guess there's hope, Ferg? Rob? LongLake? BobG?
I better get to buildin'! And my damn lake better get to thawin' as well
THE FLOATER is going to do more than sit on the trailer this year! She fired up on the 2nd turn of the key!!!! I added a pole for the cover and it seemed to do the trick. I only had about 5 gallons of water total on either side of the bow. It is almost impossible the way the fence is shaped to not have a little pooling there. I got the ski bar mounte. All the vest are on, noodles, rafts, AND CUPHOLDERS! We really wanted to take it out when we started dry boating, but the launch was full of crappie tournament and spoonbill snagging boats. We had to burn all the leaves, clean out the trailers and I had to put a new coat of roof paint on the big one. I really hate down and backs to the lake just not enough time to get everything done. I forgot the camera so I didn't get a whole lot of pics either.
We are going down in 2 weeks to put her in!
I think I may beat you this year TODD!
- IMAG0640.jpg (62.83 KiB) Viewed 9451 times
- IMAG0639.jpg (122.36 KiB) Viewed 9482 times
- IMAG0648.jpg (98.33 KiB) Viewed 9471 times
- IMAG0646.jpg (45.4 KiB) Viewed 9445 times
- IMAG0647.jpg (54.38 KiB) Viewed 9452 times
Looks good Craig... won't be long now and you'll be back out on the water.. I know last year was frustrating for you, but looks like you got the floater ready to go now... congrats.
Thanks Roland! If it hadn't have been Easter weekend I think we all would have stayed and took her out! 2 more weeks and she'll be wet! The Admiral was super relieved when it fired up and ran for almost 10 minutes off and on without an issue!
We still got to get off our ass and get the sun deck done, the radio put in
Well Craig maybe we can meet up this year on the lake. BTW I've been out on the lake three times this year all ready the water's a little cold 60 deg last Thursday the last time I was on the water.
