Forester 20' rebuild
Comstocker
#1 Post by Comstocker » Wed May 14, 2014 7:34 am
After 14 yrs of summer use without benefit of a cover it's finally time for a rebuild. As part of the rebuild we're also going to change the furniture layout as we don't fish from the 'toon anymore. Here's a pic of what we're starting with, the flip-flop bench had a live well in it. We're thinking of re-using the flip-flop bench (minus the backrest) as a cooler/ottoman that we can push around as needed.
Stuffed it in the garage and started pulling off the old furniture
Getting close to the deck!
Tonight we should finish pulling off the old console and start hole drilling all the deck screws out. Hope to have the old deck off tonight, then we can start working on putting it back together! I'll do some site searching to find out the best way to pull the steering wheel and cabling. I also have to start calling local suppliers for Marine-grade plywood.
Look forward to sharing the rebuild. The only issue we've had so far was the bolts that hold the fencing on. They were long bolts with the three-finger style anchors that you hammer into a drilled hole and the plywood had rotted so they just spun. We had to drill the bolt head off and push them down through the decking. Thankfully the builder didn't use stainless hardware, so it was easy drilling! Have to buy some more beer and get back to it after work tonight!
Ken McMillan
Mayor of 100' of Paradise on Comstock Lake
Re: Forester 20' rebuild
#2 Post by HandymanHerb » Wed May 14, 2014 8:38 am
:thumbsup :thumbsup :thumbsup Good deal keep the pictures coming on the rebuild
#3 Post by curtiscapk » Wed May 14, 2014 8:40 am
Welcome! Don't forget we get a 10% discount from pontoonstuff.com
sunedog
#4 Post by sunedog » Wed May 14, 2014 12:51 pm
Comstocker wrote:Tonight we should finish pulling off the old console and start hole drilling all the deck screws out. Hope to have the old deck off tonight, then we can start working on putting it back together! I'll do some site searching to find out the best way to pull the steering wheel and cabling. I also have to start calling local suppliers for Marine-grade plywood.
You may not have to disconnect your steering cables and motor controls. I was able to loosen everything up and lay the console on its side on a support right next to my deck. Read this viewtopic.php?f=2&t=15791
#5 Post by Bamaman » Wed May 14, 2014 1:45 pm
Last time I redid the carpet on my 1985 Starcraft was about 7 years ago--when it was about 22 years old. Since the marine plywood only had two small pieces on the rear that were rotted, I didn't think about replacing the rest of the wooden deck. That job would have been really tough to do, with the plywood riveted to the crossmembers. It was a big enough job just getting the fencing and seating off to recarpet.
I'm saying that if your marine plywood is still good, don't fix what's not broken. If your plywood needs replaced, the only thing to use is marine grade. I was looking locally, and we actually have a plywood dealership selling all kinds and sizes of plywood--including marine grade.
Good luck to you on your project. My recarpeting took me about two weekends.
redbeard
#6 Post by redbeard » Wed May 14, 2014 4:27 pm
Good start on the rebuild have fun and keep the pics coming.
Comstocker
#7 Post by Comstocker » Wed May 14, 2014 4:44 pm
We're putting a new console on as well so I have to pull all the cables and controls from the old console. That steering wheel is really on there!
Ken McMillan
Comstocker
#8 Post by Comstocker » Wed May 14, 2014 4:47 pm
Thanks for the well wishes! The old plywood is starting to rot around the edges, the old hardware just spins in the wood. The local Menards wants $69.99 a sheet for 3/4" marine plywood, and we need 5 sheets. We're going to check a couple other sources as well. We figured if we change it all now and buy a good cover for it we'll be good for a long while!
Ken McMillan
fergusmj
#9 Post by fergusmj » Sat May 17, 2014 7:57 pm
I agree with just spending the extra couple hundred and replacing it now. Better to do it now than have to do it again in a few years if the other ones go bad.
Just my opinion though.
Ferg's Tritoon Build
Comstocker
#10 Post by Comstocker » Wed May 21, 2014 6:15 am
Finally making a little more progress
Deck is coming off
All the plywood is removed, still have to cut off some of the deck screws
We have furniture! We did end up ordering from PontoonStuff.com
Taking a break for the week/weekend to get other stuff ready for the cabin. Will get back after it next week putting down the new plywood!
Ken McMillan
#11 Post by curtiscapk » Wed May 21, 2014 6:39 am
Nice work!
I hope you used the discount code?!!
Comstocker
#12 Post by Comstocker » Tue Jun 24, 2014 1:24 pm
Finally got the 'toon back from the family welder. What should have been a one day job, turned into three weeks thanks to weather and other factors.
Started laying down the marine plywood last evening, hope to get time to get it all screwed down on Wednesday evening. Then on to carpet and railings!
Ken McMillan
#13 Post by curtiscapk » Tue Jun 24, 2014 1:26 pm
YEEEEEEEEEEEEEEEEEEEEEESSSSSSSSSSSSSSSSSSSSS! I love to see rebuilds! :nana :nana :nana :nana
redbeard
#14 Post by redbeard » Wed Jun 25, 2014 9:57 pm
Looking good keep up the good work. :thumbsup :thumbsup :thumbsup
Comstocker
#15 Post by Comstocker » Thu Jun 26, 2014 5:35 am
Got the marine plywood all screwed down
A heat gun and some mineral spirits made quick work of the old gate decals
And one of the new decals installed, yeah the blue finally matches!
Tonight will be gluing down and rolling out the carpet!
Ken McMillan
