make bunks slick
killerkernrich
make bunks slick
#1 Post by killerkernrich » Wed May 28, 2014 6:32 pm
who knows where to get some of that slick material to put on bunks instead of carpet......got a link??
PLP Member
NRA member
UFC fan
Re: make bunks slick
#2 Post by curtiscapk » Wed May 28, 2014 7:10 pm
#3 Post by Bamaman » Wed May 28, 2014 8:27 pm
It's nice to have an area on the bunks that are slick. But not too slick. Nothing is worse than looking in your rear view mirror and see your boat bouncing down the road. A little friction is sometimes good. And so are some great ropes as a backup to your winch.
#4 Post by ROLAND » Thu May 29, 2014 1:21 am
This may not be what you';re looking for but it is an option... it's a marine bunk spray called "liquid rollers".... you just spray it on the bunks, let it dry.... I realize this isn't what you asked about, but it's something you could use while your considering other options. I used it last summer, worked pretty good... remember what bama said... be careful and don't get to slick... The lady that cuts my hair told me that a couple of years back they dropped their boat on the launch ( V hull ) because they had unhooked the winch strap before they backed down the ramp... as they started down the ramp the boat slid right off the trailer... thousands of dollars of damage to the boat and motor.... btw I think you can buy liquid rollers at bass pro, and I know you can buy it at countless places on line.
GXPWeasel
#5 Post by GXPWeasel » Thu May 29, 2014 5:58 am
I'm still considering taking the carpet off my boards, and replacing it with vinyl, like a pvc material. I think I'm going to put this on all of my bunk boards because my boat sticks to the trailer soo badly.
"Nauti Weasel"
2005 Beachcomber Islander 26
NonHyphenAmerican
#6 Post by NonHyphenAmerican » Thu May 29, 2014 7:26 am
For my toon, the trailer bunks have lengths of plastic in place that have a tread similar to "Diamond Aluminum".
It appears to make it slick enough to help with loading and reducing friction on the logs but not so slick as to make the toon fall off the trailer inadvertently.
A quick search found ones identical to mine here:
http://www.loadrite.com/store/home.php?cat=280
They're listed as "Right" and "Left"
http://www.loadrite.com/store/product.p ... 280&page=1
Capt Sully
#7 Post by Capt Sully » Thu May 29, 2014 7:32 am
GXPWeasel wrote:I'm still considering taking the carpet off my boards, and replacing it with vinyl, like a pvc material. I think I'm going to put this on all of my bunk boards because my boat sticks to the trailer soo badly.
I would think when you back it in the water it would just float off :donno
2012 Xcurison X23C
Yamaha 90 hp 4 stroke
Maritime mobile KD4LZL
Lake Allatoona, NW Ga.
FVC USCG Auxiliary
Vietnam 66 / 67
killerkernrich
#8 Post by killerkernrich » Thu May 29, 2014 8:49 am
Thanks Guys for the links..
My lake is so low that the ramps are out of the water....so I just back it in from the shore anywhere I find a steep angle.
I just want to put the slick bunks up front, as that is the last part of the toons to come off.
PLP Member
NRA member
UFC fan
zoom650
#9 Post by zoom650 » Thu May 29, 2014 7:29 pm
I ordered my tri-toon's trailer with the plastic covered bunks. So far, it's been easy to back off or drive on and to the bow stop.
I've not yet encountered a ramp steep enough for the boat to slip, but the trailer did come with a short, adjustable aircraft tie-down cable that backs up the winch strap, and would stop the boat before it slid to far in case of the strap breaking.
steveiam
#10 Post by steveiam » Thu May 29, 2014 8:24 pm
I have done this with mine and it does help, I bought the vinyl boards from Home Depot and counter sunk them into my boards right over the carpet.
I also sprayed some waterproof silicone on the vinyl boards to help once a season.
steveiam
#11 Post by steveiam » Thu May 29, 2014 8:28 pm
And again----
My wife put the trailer in the crooked!
BobG
#12 Post by BobG » Fri May 30, 2014 8:36 am
My bunk slicks came from Bass Pro Shop.
PlaynDoc
#13 Post by PlaynDoc » Fri May 30, 2014 11:51 am
Check out this LONG thread, on pontoon forums....
viewtopic.php?f=2&t=10639&start=15&hilit=bunk
Drago
#14 Post by Drago » Sat May 31, 2014 7:53 pm
hey Killerkernwrinch,
Check the supply at http://www.superslide.com/bispecials.php#blueiron
Check this post also
viewtopic.php?f=2&t=12785&hilit=bunks
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
killerkernrich
#15 Post by killerkernrich » Sat May 31, 2014 9:14 pm
Yes I have that link thanks
Drago wrote:hey Killerkernwrinch,
PLP Member
NRA member
UFC fan
