What does this switch do?
Clearwater262
#1 Post by Clearwater262 » Sat Jun 07, 2014 5:27 pm
Hello all. New to the forum. First time boat owner. Recently purchased a boat without manual. Prior owner did not explain to me what this switch does (Run/Off switch). Any ideas? 2003 Harris Flotebote Royal Heritage 260. Thanks.
Mercury 60 Bigfoot
cwag911
Re: What does this switch do?
#2 Post by cwag911 » Sat Jun 07, 2014 5:49 pm
That should the kill switch that the lanyard fits in. The motor shouldn't run without it and if it's a Mercury it might have a recall.
Carl & Suzi
150 Honda 15x15p Enertia prop
Power assisted steering
Denver, NC Lake Norman
Pleiku, Vietnam 1971
Clearwater262
#3 Post by Clearwater262 » Sat Jun 07, 2014 7:35 pm
Roger that. Looks like I won't be getting any use out of it. Thanks for the quick reply.
Mercury 60 Bigfoot
jrolin1
#4 Post by jrolin1 » Sun Jun 08, 2014 6:38 am
You usually get use out of that switch when you can't figure out what is wrong with your engine. In my case the kids pulled the kill switch. It took a little while to figure that one out.
zoom650
#5 Post by zoom650 » Sun Jun 08, 2014 3:53 pm
Are you able to run the engine without the lanyard in place? If the engine runs, something is wrong with the switch.
#6 Post by curtiscapk » Sun Jun 08, 2014 6:51 pm
nope its a different type than the ignition run switch. It actually has a loop on the lanyard that pulls the switch down when pulled
Clearwater262
#7 Post by Clearwater262 » Sun Jun 08, 2014 7:44 pm
That sounds right. I run the boat without any type of lanyard attached to that switch. Seems to work well with no problems. I just leave the switch in the run position.
Mercury 60 Bigfoot
#8 Post by curtiscapk » Sun Jun 08, 2014 8:04 pm
I do the same no lanyard... I didn't even know I had a kill switch until I did my rebuild. It was hiding on the back underside of my old controls.... I actually will be getting one just in case....
cwag911
#9 Post by cwag911 » Mon Jun 09, 2014 10:53 am
Crazy not to use it.
Carl & Suzi
#10 Post by curtiscapk » Mon Jun 09, 2014 11:29 am
cwag911 wrote:Crazy not to use it.
yep that is why I am getting one. For 4 years I had no clue it was even there! It was on the bottom of the controller against the rail... :donno
#11 Post by curtiscapk » Mon Jun 09, 2014 11:29 am
bassn386
#12 Post by bassn386 » Mon Jun 09, 2014 11:36 am
I've never hooked my kill switch lanyard to me when using the pontoon, but I ALWAYS use the one on my bass boat when underway.
Tip on a lanyard for the kill switch: You'll need to know what mfgr. of motor you have. That's the question they asked me at the shop when I went in for a replacement.
F225 Yamaha
PlaynDoc
#13 Post by PlaynDoc » Mon Jun 09, 2014 7:54 pm
Clearwater262 wrote:Hello all. New to the forum. First time boat owner. Recently purchased a boat without manual. Prior owner did not explain to me what this switch does (Run/Off switch). Any ideas? 2003 Harris Flotebote Royal Heritage 260. Thanks.
Dude, just look at the posted picture.... can't you see the relationship between the 'run' switch, and the jogging shoes below?? While running, the switch is up.... when you take them off, the switch is down.
Bugsbunnyboater
#14 Post by Bugsbunnyboater » Mon Jun 09, 2014 10:19 pm
I had the same type of switch on an old Mako I had.
I was able to find a replacement lanyard at academy sporting goods.
