Starter problems
FAT BOTTOM GIRL
Starter problems
#1 Post by FAT BOTTOM GIRL » Sun Jun 08, 2014 4:48 pm
Can I change out the starter motor on my party cruiser while in the river at the dock ?
I removed the batteries & put a plywood board in the battery/engine compartment & put foam boards to level the ply & can't find to b sure the bolts that fasten the starter to the case , does anybody know where to find an exploded view to illustrate how the starter bolts up to the engine ?
Man this bites ! Wished it would have happened while on the trailer before I put it in the river !!
I tryed bypassing the selinoide to start up & just get clicking noise. 2 new batteries & no start. It would turn over but just clicks now ?
03 suntracker party cruiser 3.0 I/O
Re: Starter problems
#2 Post by badmoonrising » Sun Jun 08, 2014 9:17 pm
Can it be done ? Yes. Not very easy to do as it is cramped in there. There are 2 bolts, facing downward. Should be 1/2 inch. When you bypassed the solenoid, did you bypass the starter slave solenoid mounted on top of the motor, or the main solenoid on the starter ?
The slave solenoid has an EXTREMELY high failure rate. I had 2 boats with the same engine. 3 solenoids on my Starcraft in 10 years and one on my Party Cruiser after 2 years.
I swapped it with a gold cart (very heavy duty, metal case) solenoid. Never had the problem again.
Here's a video that may help.
http://www.youtube.com/watch?v=3yksWGzWuKU
Here's a diagram of the 3.0 starter:
FAT BOTTOM GIRL
#3 Post by FAT BOTTOM GIRL » Mon Jun 09, 2014 3:10 am
Ok. Now that's what I needed.
I just bypassed the starter solenoid & unaware of the one that's remote & more accessible , hoping that's where the problem is. :scared
Soon as I get to the boat after work the battery is going back in !
Does the solenoid go bad slowly ? It seemed like the motor didn't like the cooler mornings. On Saturday it was a cold start in the morning engine would turn over like a weak battery & then just click. Shortly after just click.
Just bought 2 new battery's , they both can't b bad.
As in the video fan , lighting & horn work fine !
Hope this works , the starter is going to b a PITA & I don't have monkey arms , more like Trex!
#4 Post by badmoonrising » Mon Jun 09, 2014 4:40 am
Yes, at first the solenoid will randomly not engage then get progressively worse. 99.9999 percent of the time it's the slave solenoid. Only time the starters go bad is if there's a leak in the bilge enough to cover the starter. Good luck.
FAT BOTTOM GIRL
#5 Post by FAT BOTTOM GIRL » Mon Jun 09, 2014 5:42 am
That's encouraging news !
It was sad setting at the dock & scratching my head & watching all the other boat traffic zoomin & drifting by , all I could do was to enjoy there wake minutes later.
Was a great weekend otherwise !
Can't wait to get outa work now , must stay focused !
Much thanks
MH Hawker
#6 Post by MH Hawker » Mon Jun 09, 2014 11:14 am
The first step is to make sure its a sel or starter problem, Clean each and every terminal first no matter how good it looks. They can look fine but they arnt. Then see how it starts, 90 % of all starter problems is bad connections.
FAT BOTTOM GIRL
#7 Post by FAT BOTTOM GIRL » Tue Jun 10, 2014 5:54 am
Tried jumping the slave solenoid on top the engine & got a louder clicking noise & the one on the starter barely sparked , no turnover.
Hooked up just the heavy starter cables nothing else , same thing.
Starter is out now , need to get a magnet & fish out a bolt from the bilge $ an inspection mirror to c if there's a shim anywhere to b found.
#8 Post by badmoonrising » Tue Jun 10, 2014 4:12 pm
There was no shims on either of my boats, but if the starter is a bit "off", it may rub the flywheel. My older 3.0 was sensitive to alignment, the Party Cruiser, not. Don't know if anything was changed since the Stacraft's 3.0 was a '99 and the PC's a 2006.
FAT BOTTOM GIRL
#9 Post by FAT BOTTOM GIRL » Wed Jun 11, 2014 4:32 am
Went fishing with a magnet , got the bolts , no shim. Didn't appear to b any sign of one compressed by bolts & with the way the paint spray pattern looked either ?
FAT BOTTOM GIRL
#10 Post by FAT BOTTOM GIRL » Wed Jun 11, 2014 4:35 am
Tested the starter on the test bench at work & proved to b defective.
FAT BOTTOM GIRL
#11 Post by FAT BOTTOM GIRL » Wed Jun 11, 2014 4:38 am
I don't know weather to play the powerball or stay clear of mirrors! Lol
FAT BOTTOM GIRL
#12 Post by FAT BOTTOM GIRL » Sun Jun 22, 2014 11:56 am
Got the engine running !!
First starter I received from West marine was a no go(figures)West with great costumer service overnite shipped the correct starter at there cost !
Experience pays , taking out the starter had me worried but got the new one in with some effort.
MH Hawker was correct , the positve leads was like an anodized coating needed scraped & cleaned up , could b the cause of the starter going bad ?
Thanks again !!
This forum rocks !!
