Gas grill location
Gonefishing
Gas grill location
I am getting ready to mount my grill. I have seen most grills are mounted at the rear of the toon. Don't you worry about fumes from the gas tank. All the toons tank is at the rear. Fumes and flame don't go while. Just asking. My grill connects to a regular propane tank I purchased a pedestal stand for it now wound erring whereto mount it. Rear or front. Would work better in the rear but I worry about the fumes from the gas tank. Reason for my question. Thanks guys
Bob Jacksonville, Nc
2013 Excursion X23 RFC
2013 115 Yamaha
Pulled with a Ford King Ranch
2013 115 Yamaha
Re: Gas grill location
I have my grill pedestal mounted on a stern corner. My gas tank is permanently mounted below deck in the extended transom. With the tank not being totally contained, and the abundant ventilation, fumes don't accumulate, so ignition is not a concern for me.
2010 Suntracker 24' Sunchaser
2009 Mercury 90hp EFI/4S
2007 Ford Expedition 4WD
I've got mine in the front for the very reasons you sight. Plus, that's the end on the beach usually so there's no running from the back of the boat to the front to get the food out.
- Grill.jpg (63.07 KiB) Viewed 2000 times
2007, 2570 Crest LE II
Yamaha F150
Yamaha F150
- chopper6358
mine is in the front,,, no problems with it so far
- 10472847_10204170388562658_2235428242343301659_n.jpg (75.14 KiB) Viewed 1978 times
- 10433306_10204170386202599_3209184126135715283_n.jpg (71.1 KiB) Viewed 1976 times
