Water hose
Water hose
I have a broken fitting on side of my 08 Mercury 115 hp 4 stroke, sorry haven't got my manual yet so I don't know part names but I'll try to post pic, it's a 3/8" rubber hose that goes to a fuel something, maybe cooler? Broke and now water don't come out back of motor, need to know what it's called to get new one
- image.jpg (35.38 KiB) Viewed 2270 times
Re: Water hose
Better pic, I hope
- image.jpg (12.6 KiB) Viewed 2156 times
- image.jpg (13 KiB) Viewed 2158 times
Re: Water hose
I'm confused by the red lines, but I think the box you're referring to in that pic is the fuel pump assembly. It's uses water pressure to switch hi/lo fuel pumps...somehow. I have seen on mine where the plumbing does also feed the pee-port.
2010 Suntracker 24' Sunchaser
2009 Mercury 90hp EFI/4S
2007 Ford Expedition 4WD
Re: Water hose
If you have your engines serial number, and these pictures, (or better yet, a cell phone picture of the part on your engine) and bring it into your local boat dealership / parts place, and show them what you need. This is what they do, and usually know exactly what you're talking about. At least, from my experience.
"Nauti Weasel"
2005 Beachcomber Islander 26
Re: Water hose
Great guys thanks, maybe that'll fix my other issue, it'll only run up to 4900 rpm at 19 mph when other boats like mine run 29 to 31 mph at 6200 rpm
Re: Water hose
im not a mechanic, nor prop expert....smuckie wrote:Great guys thanks, maybe that'll fix my other issue, it'll only run up to 4900 rpm at 19 mph when other boats like mine run 29 to 31 mph at 6200 rpm
but, 4900 at 19mph when you expect more, could be a prop size/pitch issue, more than motor issue.
Re: Water hose
That's why I went a head a bought it, I thought the same thing, but it also doesn't rev up in neutral
Re: Water hose
go here
https://webapps.brunswick.com/literatur ... eSearch.do
Enter serial number and you can pull up the parts catalog. Good luck.
Ferg's Tritoon Build
