Adding a Hot Water Heater to a Suntracker Party Cruiser
phaseonephotog
#1 Post by phaseonephotog » Thu Jun 26, 2014 7:22 am
The Cruiser has a gravity shower from two 40 gallon fresh water tanks on the roof but I want to add a hot water heater with a better pump for volume. I would also plumb the sink to the heater as well. The question is what type of HW heater and how to install?
Jay
chopper6358
Re: Adding a Hot Water Heater to a Suntracker Party Cruiser
#2 Post by chopper6358 » Thu Jun 26, 2014 7:41 am
Use a 12 volt tankless propane water heater . Can get them portable or hard mounted....just search 12volt tank less water heater you can get them any where and you can get pretty good 12 volt pumps .on any rv site
#3 Post by badmoonrising » Thu Jun 26, 2014 12:13 pm
If you have an I/O, you can install a heat exchanger system. A friend of ours has one installed on his cruiser. Only bad part is you have to start the engine for hot water.
FAT BOTTOM GIRL
#4 Post by FAT BOTTOM GIRL » Thu Jun 26, 2014 12:24 pm
Check out camp chef.com & look at the triton 5L water heater. I'll try to get some pics. & show how I installed
03 suntracker party cruiser 3.0 I/O
FAT BOTTOM GIRL
#5 Post by FAT BOTTOM GIRL » Fri Jun 27, 2014 2:58 am
Mounted the heater to the wall behind the ladder.
FAT BOTTOM GIRL
#6 Post by FAT BOTTOM GIRL » Fri Jun 27, 2014 3:00 am
The 12 volt pump on the floor in the same area.
FAT BOTTOM GIRL
#7 Post by FAT BOTTOM GIRL » Fri Jun 27, 2014 3:03 am
30 gal. food grade barrel & ditched the tank on the roof for more room topside.
FAT BOTTOM GIRL
#8 Post by FAT BOTTOM GIRL » Fri Jun 27, 2014 3:05 am
Propane tank is behind u to the right as u face the ladder.
FAT BOTTOM GIRL
#9 Post by FAT BOTTOM GIRL » Fri Jun 27, 2014 3:08 am
& to b on the safe side a backup CO alarm.
kiowacampers
#10 Post by kiowacampers » Fri Jun 27, 2014 7:14 am
For some reason, I don't see any pictures, just an x. Does everyone see them?
Carol and Jesse (aka The Bickersons)
2006 Suntracker 32ft. Regency Signature Party Cruiser w/150hp Merc Optimax
2003 Ford F350 Diesel 6.0
11 ft. Quicksilver 330 Dinghy w/15hp Evinrude
A massive amount of dogs
In the middle of nowhere, Agate Colorado
#11 Post by badmoonrising » Fri Jun 27, 2014 9:06 am
I can see them fine.
#12 Post by RcgTexas » Fri Jun 27, 2014 9:24 am
I can see um but I need a 60 inch moniter to see um whole.
Cowracer
#13 Post by Cowracer » Fri Jun 27, 2014 12:33 pm
not for nothing, but you may not need hot water at all. I have an outside shower on my camper. The water sitting in the freshwater tank on a hot day is plenty warm for a shower. If you want, paint your tanks black. The water will be hotter than you can stand.
Tim
phaseonephotog
#14 Post by phaseonephotog » Tue Jul 01, 2014 10:24 am
Thanks for ALL the suggestions. My concern with propane is safety, especially around the engine compartment.
I am thinking about a hot water heater that runs off 110 at the dock and engine warming on the hook.
I also agree that the gravity fed top tanks are hot enough during the day, but we sleep at the slip and the am shower is too cold.
Can someone suggest where to purchase a hot water tank system AND do you guys agree this is a doable solution to make things
more comfy for my female companion of 31 years. :)
Bamby
#15 Post by Bamby » Tue Jul 01, 2014 11:51 am
We've got a water heater similar to this and it does a pretty darn decent job even in cold weather camping where we've mainly used it. If your slip water is OK you can use it as a source for this unit if you don't mind the possibility of contaminating the unit. It's also the compact and packable unit I could find when we got ours.
