new prop is much better, 15 inch 11 pitch, the motor almost got to 4500 rpms, which is much closer to top end on the i/o
the boat as she sits is running 20-21 mph on gps. oh and the leak is also fixed
so now that we have a baseline and a prop that is close, i am looking at making improvements as we go along.
first a better 11 pitch prop. the 15 pitch we had before was just way too much prop at my altitude.
second or maybe first what is your opinion on this POS anti vent/trim plate the PO installed?
it is hard to tell in the photo but is actually bends down slightly in the front edge. seems as i trim up a bit to raise the log it would actually dig in and cause drag rather than helping at all. when we are trimmed the tailing end are out of the water about an inch.
I have used these on other boats, but on the toon it just seems like a point of resistance.
what do you think?
I took it off with the intention of reshaping it and getting rid of the leading edge and making it drag less. now that it is off i am thinking i may be better off without it.
