What speed are you getting at WOT and the size of you boat
Bugsbunnyboater
1995 Sweetwater 18 foot... 10 mph. 25hp Tohatsu
What speeds are you getting.
Re: What speed are you getting at WOT and the size of you boat
2014 Sun Tracker 18 foot with 60 HP 4 Stroke Mercury 2 adults and 30 gallons of gas, cooler and full gear 21 MPH
Soonertoon
22 ft G3 Suncatcher w 115 Yamaha 4 stroke 30 m.p.h. wth full fuel tank, Bimini up, 2 adults and 2 teenagers.
Broken Arrow Ok
2014 G3 Suncatcher
115 Yamaha 4 stroke
2014 G3 Suncatcher
115 Yamaha 4 stroke
a 91 grumman 20 footer with a 50 HP 16 mph with four in it, after the rebuild w a 90 HP added I get 21 with four and 20 gallons of fuel
07' Bennington 2275rl w/ Honda 150, 40mph
Carl & Suzi
150 Honda 15x15p Enertia prop
Power assisted steering
Denver, NC Lake Norman
Pleiku, Vietnam 1971
1995 21ft Beachcomber converted to tritoon with 135 Honda with 4 adults, bimini up, 5000rpm(SEE below), and 30 gal gas = 31.3 mph/ GPS
That's with a bent prop shaft.(Just discovered that) Seems dealer missed that detail when he sold me the motor.
That's another story.
Matt in Houston
Xcursion X-25C w/ Yamaha 150 4 stroke and Enertia 15 pitch prop. Rear bimini open, 2 adults, one kid, 1/2 tank of fuel, and motor mounted in top hole. 36 MPH GPS at 5600 RPM, 9 hours on motor and outside temps @ ~95 degrees.
2014 Xcursion X-25C Tritoon - XS Pkg - 150 Yamaha 4 Stroke - 15p Enertia
Tankplunkett
1994 Playcraft with 90 horse Johnnson, bimini top up, 2 adults and a little gear, 25 mph.
1985 Mirrocraft, 20' with 1985 Evinrude 25 hp.
GPS shows 18 mph with just me on the boat (in addition to 12 gallons of fuel, battery anchors, gear etc.), 14-15 mph with 3 adults.
KPC
KPC
2010 Crestliner 2385 Batata Bay 115 Honda 4 Stroke. 26mph with 4 people and a full tank on a good day!
- 20140616_152954.jpeg (181.05 KiB) Viewed 11451 times
1999 Active Thunder Tantrum 550HP 502CI
2010 Crestliner 2365 Batata Bay w/115 Honda
2014 Fishn' Barge 22 DLX, 90FS Merc 28mph 1/2 tank, 2 peeps on board.
2009 Tracker Fishing Barge 21 - Mercury 90 HP 4 stroke, 38MPH GPS @ 5800 RPM with a 13.25 X 17 prop. Lifting strakes help a lot!
2007 GMC Sierra
2007 GMC Sierra
1992 24 ft Suntracker with a 2013 Yamaha 115HP = 25 mph
see my sig!
2013 Sylvan Mirage 8520 Cruise - 20 footer with a Mercury 50 Bigfoot.
GPS'd at 18.5mph with 2 people, 2 batteries and a full tank of fuel (130L)
