First Rebuild Start
First Rebuild Start
Well to start i'd like to thank all the guys here for sharing all thier knowledge , i've learned alot from Reading, Reading, and Reading. I bought this 1997 Sylvan 24' toon, has a older 200 Mercury that my Boat mechanic Friend checked out and said all is good and didnt looked ever worked on, runs great, was doing 30-MPH, but i had a guy here selling a Water glide for cheap and i installed it now im doing 40 -MPH with a 3 blade prop ,will look into a 4 blade after rebuild,i think will work a little better. i have had it for 1 year and now its time to rebuild with all new Seats , console,side pannels , and carpet, and double tops,can anyone give me a little direction, i plan on ordering all my stuff from here at Pontoon Stuff but i dont see seats other that White and red,blue,yellow,etc , i want to go with the black skin and tan seats do they sell tan seats??
- IMG_0740.jpg (91.13 KiB) Viewed 12267 times
- IMG_0741.jpg (108.87 KiB) Viewed 12268 times
- IMG_0742.jpg (97.92 KiB) Viewed 12267 times
- IMG_0735.jpg (93.86 KiB) Viewed 12266 times
- IMG_0734.jpg (90.75 KiB) Viewed 12269 times
Waterlogged
Re: First Rebuild Start
Welcome aboard, hope the reconditioning goes as planned.
Glenn
Glenn
2008 Mercury 115 4 stroke
Welcome and good luck on the project.
In regards to seats. You can only get the few colors shown. That's the reason I went with custom colors from Veada.
Also, may want to make sure and reinforce the transom as I'm assuming it wasn't ever meant for a 200hp motor unless it was already beefed up.
looking forward to watching the rebuild.
Ferg's Tritoon Build
Waldo,
Welcome to the forum. If you get a chance post a picture of your water glide on the forum.
I will post Waterglide pics when i returne home , and the transome seems really beefed up it does not budge any i tried to shake it a bit but nothing, i will be home this weekend and finished getting the carpet removed, undecided with the colors yet but i'd like it all to color match ,Seats , New fence paneling,and top.
James Myers
Hi Waldo
We don't have any seats with black but we do have this new color that is Ivory, Tan & Beige. Thank you for the opportunity!
- 304.jpg (112.34 KiB) Viewed 12093 times
Well i did get too do a little work on her this weekend pulled the old carpet out and wow what a job, but im a hard headed guy and like to try new things i had a friend try the restore 10X and i did the same and wow looks really good , im from way south Louisiana and it was 100* outside in a full sun and this stuff is thick, i tried this on a scrap piece of wood and then tried to scrap it off instaed it pulled the ply's off t he plywood, so i think this will work, and thanks for the seat info we are leaning to the Ivory,Tan, Gray i think thats what ya had on the pics, so here is a few pics and i did get a copuple pics of the waterglide as somme asked, it will be a month before i get to go back home and do more i'll order all my stuff in this time to be at home when i get back ,again thanks to all
- 1.jpg (93.71 KiB) Viewed 12001 times
Pics
- 8.jpg (87.93 KiB) Viewed 11997 times
- 7.jpg (93.3 KiB) Viewed 11991 times
- 6.jpg (97.82 KiB) Viewed 11991 times
- 5.jpg (88.09 KiB) Viewed 11989 times
- 4.jpg (105.11 KiB) Viewed 11984 times
- 3.jpg (107.75 KiB) Viewed 11984 times
- 2.jpg (97.23 KiB) Viewed 11987 times
Waldo,
Thanks for the idea to use Retore 10X !!!
If the decking on my used pontoon is still good, I may use that to save some money!
Tell me, did you just coat the top or did you do the undercarriage as well?
Thanks again!
Thanks again!
Well i got a chance to start the rebuild again and in fact i ordered the same Seats that James sent my a pic of just yesterday , the only thing was a few pieces are on back order until the first of the month. i ordered the Black panel sheeting from pontoonstuff and it came out great, and wow the discount saved me between the seats and other stuff i ordered $400, so thanks for the code. the steering helm will be here in the next day or so so i will be able to mount the steering and controls and start the wiring for lights and stuff before i do the under sheeting so here are a few pics
- IMG_1987.jpg (251.97 KiB) Viewed 10984 times
- IMG_2001.jpg (237.47 KiB) Viewed 10990 times
- IMG_1986.jpg (221.09 KiB) Viewed 10984 times
Ok i got a question as you can see my toons are stained but i did was them with alumabrite well something like it but i never buffed a toon before , i did a spot with aluminum rim cleaner like mothers with a can hand held , the one that shakes back and forth, will i need a buffer ? what kind or type and how many rpms , i have looked and read but so many ways can someone direct me on what i need and a method to do this ,thanks
Looking Good Waldo! I didn't polish my logs because I did not want to open that can of worms., I cant help you there but you seem to have it all under control.
Well im about 99.9 % complete have a table and running lights left , but we took "WALDO " out this weekend and so many people thought it was brand new, it made me proud to tell them its a 97 model, i have to thank all here who have posted and helped me along the way, here are a few pics, i forgot to take pics of the underside but i did under skin it using corrugated sheet metal from lowes , came out great and serves the purpose, so THANKS.
- IMG_2247.jpg (86.64 KiB) Viewed 10527 times
- IMG_2250.jpg (73.78 KiB) Viewed 10528 times
- IMG_2252.jpg (71.66 KiB) Viewed 10524 times
- IMG_2274.jpg (57.67 KiB) Viewed 10515 times
- IMG_2275.jpg (63.96 KiB) Viewed 10520 times
- IMG_2273.jpg (88.8 KiB) Viewed 10519 times
Looks really good!
Fantastic work!
