Moving a carport
Re: Moving a carport
#16 Post by RcgTexas » Mon Oct 13, 2014 9:09 am
Just curios, Noticed the fence behind the cover is open. Will it stay that way and are you going to be able to come in that way? Is that a small church behind there?
MH Hawker
#17 Post by MH Hawker » Mon Oct 13, 2014 9:19 am
RcgTexas wrote:Just curios, Noticed the fence behind the cover is open. Will it stay that way and are you going to be able to come in that way? Is that a small church behind there?
I am on a corner lot and yes thats a church behind my lot and its a lot easier to back it in from their lot, You can see a bit of the lot in the new pic. I have talked to the pastor and he is ok with it and i plan on putting in a set of twin gates in the spring. In fact its a old and falling down privacy fence i am planing on replacing with chain link in the spring or summer.
this is how i pulled out the stakes
chain rachet.JPG (395.07 KiB) Viewed 1244 times
#18 Post by RcgTexas » Mon Oct 13, 2014 2:20 pm
:thumbsup Looks like you have under control. yea that's exactly how I had it pictured in my mind. You have it going your way now.
MH Hawker
#19 Post by MH Hawker » Wed Nov 12, 2014 10:49 am
Thought i would add one more pic, a lot of work but here is the end result
in carport.JPG (285.64 KiB) Viewed 1158 times
#20 Post by RcgTexas » Wed Nov 12, 2014 1:36 pm
That cover is going to be good. high enough to work under but low enough to keep "stuff" from flying in.
MH Hawker
#21 Post by MH Hawker » Wed Nov 12, 2014 4:52 pm
i can just walk under it, on the side i will bang my head.
#22 Post by RcgTexas » Wed Nov 12, 2014 9:59 pm
Better that it is lower though, might stay cleaner, as in leaves and stuff.
