Replacing my steering wheel
jsquaredz
#1 Post by jsquaredz » Sat Nov 22, 2014 11:09 am
I am trying to replace my steering wheel with an aftermarket "Destroyer type" wheel. I removed the 3/4" bolt on the wheel, but I cant get it to budge off. Here is a photo.
http://jsquaredz.com/wp-content/uploads ... 142332.jpg
Re: Replacing my steering wheel
#2 Post by HandymanHerb » Sat Nov 22, 2014 11:24 am
Spray some WD 40 in there and let it sit, then put the nut back on, have someone hold pressure on wheel and hit the nut with a hammer
MH Hawker
#3 Post by MH Hawker » Sat Nov 22, 2014 3:51 pm
+ 1, normally a light tap and its lose. When i did my rebuild i also looked at the destroyer wheels and found a smoking deal on this one.
new consol 10.JPG (115.56 KiB) Viewed 1657 times
#4 Post by RcgTexas » Mon Nov 24, 2014 9:46 am
Be careful don't hit too hard to mess up the steering box! but do soak it well and you might try a gear puller!
Be sure and put anti-seize on the new wheel !
sunedog
#5 Post by sunedog » Tue Nov 25, 2014 6:06 am
Gear puller wouldn't be feasible on mine. The only thing to pull was plastic. Herb has it right above. Thread the nut on to protect the threads then give the nut a moderate whack with a hammer while pulling out on the wheel. It should pop loose. I was able to do it by myself.
