Log brackets
Crab Island Cruiser
Log brackets
#1 Post by Crab Island Cruiser » Mon Dec 22, 2014 5:16 pm
I'm trying to find the brackets that 'were' welded to the back of toon logs. The PO had problems with the depth finder
and decided to take it off. He removed the brackets from the back of the toons as well. Guess he figured he didn't need them
anymore.
Is there a CO that makes those or would I be better off having a metal supplier make me some?
22' sunchaser
Thx
07 22' Sun Chaser
Yami F115 power
low and slow
Re: Log brackets
#2 Post by RcgTexas » Mon Dec 22, 2014 7:44 pm
The brackets I have on my boat logs are not low enough, so as to be able to mount a transducer low enough to let be useful at higher speeds.
If I were to have new brackets made I would have them come out flush with the bottom of the logs for that reason.
A sheet metal shop can probably make you some and weld them on.
Just keep that in mind if you do.
