1988 Bass Buggy winter/Gravity project in New Mexico
Ercarp
Re: 1988 Bass Buggy winter/Gravity project in New Mexico
#46 Post by Ercarp » Mon Mar 16, 2015 9:14 am
Hah, somehow I put a pic of my family in there...stupid computer
#47 Post by RcgTexas » Mon Mar 16, 2015 6:57 pm
Welding is looking good! The good news is that it is guaranteed ! if it breaks you will weld it again! :thumbsup
Ercarp
#48 Post by Ercarp » Mon Mar 23, 2015 9:35 am
I spent Saturday looking for pin holes in the welds (think I poisoned myself with fumes). Had a fancy pressure gauge (thanks grandpa), to double check. I got all the pin holes on the outside, unfortunately I found two that are only leaking on the inside of the strake...trying to figure out a solution to that.
2015-03-21 11.12.57.jpg (102.86 KiB) Viewed 15400 times
Anyhow, being frustrated with the two hard to get to pin holes (very small, I lost 2/10 of one pound of air in 3 hours). I decided to move forward. Here what it looks like for one person to install a center tube.
2015-03-21 16.04.22.jpg (175.16 KiB) Viewed 15400 times
Here she is, installed for the last time (hopefully)
2015-03-21 16.59.58.jpg (127.58 KiB) Viewed 15398 times
and from the front
2015-03-21 17.00.21.jpg (138.25 KiB) Viewed 15399 times
Weekends seems to go too fast, so no time to waste. The deck went on!
2015-03-22 17.48.16.jpg (153.38 KiB) Viewed 15401 times
2015-03-22 17.48.42.jpg (151.65 KiB) Viewed 15398 times
2015-03-22 17.49.03.jpg (121.87 KiB) Viewed 15394 times
2015-03-22 17.49.28.jpg (125.59 KiB) Viewed 15391 times
2015-03-21 16.04.22.jpg (175.16 KiB) Viewed 15384 times
#49 Post by curtiscapk » Mon Mar 23, 2015 12:47 pm
Nice work man!
Ercarp
#50 Post by Ercarp » Mon Mar 30, 2015 7:21 am
Quick update from the weekend. Family was a huge help this last weekend. They pitched in and helped me get the floor on. I am going with carpet inside the playpen, and using kiwigrip (rhino-lining type stuff) on the front (3.5 feet) and back (2 feet).
2015-03-28 17.44.57.jpg (173.53 KiB) Viewed 15301 times
2015-03-28 18.05.29.jpg (108.72 KiB) Viewed 15297 times
2015-03-28 18.05.47.jpg (199.77 KiB) Viewed 15296 times
my plan by the end of this last weekend was to have the floor on, rub rails on, and the playpen panel primed. I got the floor on and ran into a big snag on the rub rail. I did not have enough!
2015-03-29 19.09.23.jpg (125.16 KiB) Viewed 15298 times
Not enough in a single piece. But, like Toonguy said the front of the bassbuggies are weird (look at first couple pictures). I tore apart the weird parts and was able to piece together enough to make it work.
2015-03-29 19.09.53.jpg (123.1 KiB) Viewed 15299 times
Ercarp
#51 Post by Ercarp » Tue Mar 31, 2015 9:58 am
I apologize to spursfiend (I am kinda highjacking his thread).
My budget, or lack there of, has put me at an impasse. I have striped the playpen panels and primed with an aluminum self etching primer (from rattle cans). What are the draw backs/disadvantages of using a rattle can to paint the panels? The advantages I see are a variety of colors, ease of use and easier on the pocket book. If a rattle can is not the end of the world, what type (brand/enamel etc.) should I use? If rattle cans are the end of the world and if I can round up a HVLP paint gun, what kind of paint do I get for that? How many of you guys have rattle canned your panels and how is it holding up?
Any suggestions would be a help.
ToonGuy
#52 Post by ToonGuy » Tue Mar 31, 2015 10:13 am
Ercarp wrote:I apologize to spursfiend (I am kinda highjacking his thread).
I think you meant to post this on a different thread... :donno
Ercarp
#53 Post by Ercarp » Tue Mar 31, 2015 11:21 am
I hope not. :!:
I saw that spursfiend had started a topic (in rebuilds section) about painting rails. That is why I commented about highjacking his thread/topic.
I am really kinda looking for input/votes for or against a rattle can paint job. If it is overwhelmingly against, what type of paint (and where) do I get for the HVLP spray gun? :nana
Ercarp
#54 Post by Ercarp » Wed Apr 01, 2015 7:01 am
I ordered my furniture (from pontoonstuff), it is supposed to be in on friday. Those guys have been great to deal with, fast replies on communication and fast on deliveries. A little disappointed with them concerning the furniture, they did not have anything on their website about the furniture being on back order. Most all the cushions are on back order until may, but they are sending the bases. Oh well, probably mostly my fault for waiting till last minute to order.
Concerning the bases, is it obvious how to install them? I am hopeful that there are good instructions, as far as spacing etc.. Anyone have any good tips?
ToonGuy
#55 Post by ToonGuy » Wed Apr 01, 2015 10:26 am
Gotcha...I was a little confused by seeing that post in this thread :drink4
At this point I have no advice, just input. A paint job is only as good as it's base, to a certain extent. Rattle can primer is just that...it's not 2 part sprayed from a gun so that's a step backwards. However, if you decide to mix and spray the top coat it will be harder than rattle can, so that will help. It really depends on how well you can take care of it. I've seen fantastic rattle can jobs. But we all know mix & spray will hold up to the bumps & bruises better. So at this point I think it's a crap shoot.
On to your bases. Too bad about the back orders...IMO that should be clearly posted. Here's how I mount my seating: I drill/bolt the bases together to form any groupings, then mount the cushions to them. Then I use the (hopefully) supplied SS washer head screws to screw them to the deck. Don't go through the drain holes, make your own. The screws go through the plastic and into the wood with out pre-drilling ...no problems.
My suggestion is to NOT mount the bases to your boat with out the cushions. You will end up having a difficult time positioning the seats where you want them. The base will not always end up perfectly square and tight against the railing in every spot. After your cushions are mounted, it's no big deal but you may not be able to mount them without taking the base loose from the floor and making another set of holes. That's my .02 8)
Ercarp
#56 Post by Ercarp » Wed Apr 01, 2015 11:51 am
Great info thanks!
I said that I had rattle canned the primer on...but it did not happen (was on the list to do, then the boys baseball games started, then something else yadda yadda life got in the way). Thanks again Toonguy, I am going to farm out the paint job.
On the cushions, I am hoping I missed something on the website. They have been nothing but great to work with, no hassles other than my disappointment of them not seeing my lack of planning as their emergency :roll: I will continue to do business with them.
I am taking Friday off and hope to get rub rails on, console in and wired. Pics on the way
#57 Post by curtiscapk » Wed Apr 01, 2015 12:02 pm
Ercarp wrote:I ordered my furniture (from pontoonstuff), it is supposed to be in on friday. Those guys have been great to deal with, fast replies on communication and fast on deliveries. A little disappointed with them concerning the furniture, they did not have anything on their website about the furniture being on back order. Most all the cushions are on back order until may, but they are sending the bases. Oh well, probably mostly my fault for waiting till last minute to order.
When I look at their site it shows the grey blue on BO till 5-1 unless they changed it after your order????
Ercarp
#58 Post by Ercarp » Wed Apr 01, 2015 12:42 pm
I am still not seeing it. Can you post a screenshot of where your looking? Not that it matters, I am just curious where my ignorance has reinforced my lack of planning. Here is what I ordered...from an ipad
Just so we are clear I am not upset at pontoonstuff.com, they have done their job great. I am disappointed in myself for waiting to order at the last minute
#59 Post by curtiscapk » Wed Apr 01, 2015 12:50 pm
AAAAH. I looked at the single seats not the groups! My bad. Check your PM.
James Myers
#60 Post by James Myers » Wed Apr 01, 2015 1:56 pm
Hi Ercarp
It's not your fault at all! You should be able to order at any time and get your seats fast... that's how I built my business and unfortunately I'm failing on that aspect at the moment. As I write this I've been going through all our products and updating groupings, etc that are effected by our "out of stock" situation. We had an explosion of sales that we couldn't ramp up for and it's blown through a ton of my inventory and put us back a month on some of our most popular colors and items. By the end of the day everything will be updated so customers won't get surprised like this.
I am very sorry for this inconvienece and if you could email me at jmyers1165@gmail.com I'd like to find a way to make the waiting a bit more bearable... please contact me with your order number when you can.
Thank you so much for your business and I apologize to anyone else whose been effected by us not having properly inventory. I'm doing everything I can to get us caught up and we will be expanding our current 30,000 square foot warehouse to 70,000 square foot this fall so we won't have this problem next year.
James Myers
President
PontoonStuff.com
James P Myers
President
PontoonStuff.com
jim.myers@pontoonstuff.com
http://www.pontoonstuff.com
