1988 Bass Buggy winter/Gravity project in New Mexico
Ercarp
Re: 1988 Bass Buggy winter/Gravity project in New Mexico
#61 Post by Ercarp » Mon Apr 06, 2015 8:23 am
I have to say, for anyone following any rebuild and thinking of replacing furniture, you will not find many other companies that can top pontoonstuff.com. They are an example to the rest of us business owners of how a good business needs to treat its costumers. Thanks Pontoonstuff!
I did not get a lot done this last weekend. The rub rail is on, and a few other miscellaneous items. I received the bulk of my furniture. I started to lay all that out to get an idea of space. I took the play pen panels down to the paint shop. For the next few weeks most of the progress is going to be "hidden" stuff (wiring for console, moving batteries and fuel tank, etc.). Here are a few pictures of where I am.
2015-04-01 13.10.15.jpg (154.62 KiB) Viewed 15806 times
Rub rail is on
2015-04-03 18.17.04.jpg (161.75 KiB) Viewed 15803 times
close up of spliced in front piece
2015-04-03 18.17.13.jpg (140.45 KiB) Viewed 15804 times
picture of the spliced in side pieces
2015-04-03 18.17.27.jpg (137.1 KiB) Viewed 15803 times
I used Toonguys suggestion to cut the rub rail down, to bend it around the radius at the front and back. Came out pretty good
2015-04-03 18.17.39.jpg (185.16 KiB) Viewed 15807 times
2015-04-03 18.18.13.jpg (176.63 KiB) Viewed 15806 times
ToonGuy
#62 Post by ToonGuy » Mon Apr 06, 2015 8:54 am
Lookin good!!!
Ercarp
#63 Post by Ercarp » Tue Apr 14, 2015 8:01 am
crazy how you can work so hard on something and not see much progress, but then do little to no work and the progress seems to have leaped ahead. I was traveling this last weekend and did not do any work to the boat. I have been piddling around with it in the evenings. Paint shop finished, a few parts where delivered. So, here we go!
2015-04-14 07.25.34.jpg (123.12 KiB) Viewed 15701 times
2015-04-14 07.26.00.jpg (125.82 KiB) Viewed 15705 times
Rounded up an 18 gal tank
2015-04-14 07.30.43.jpg (103.91 KiB) Viewed 15708 times
robbed the fuel gauge as well. I did not want to mount the gauges directly to the console so I whipped out a bezel.
2015-04-14 07.30.21.jpg (89.12 KiB) Viewed 15703 times
Console with old steering wheel (I re-used a lot of old parts, that way when I get bored I have upgrades to make later :happy )
2015-04-14 07.30.36.jpg (46.78 KiB) Viewed 15698 times
2015-04-14 07.29.54.jpg (52.86 KiB) Viewed 15697 times
2015-04-14 07.31.00.jpg (44.86 KiB) Viewed 15703 times
#64 Post by curtiscapk » Tue Apr 14, 2015 8:11 am
Woohooo! Someone got some of their bases! :nana :nana :nana
Ercarp
#65 Post by Ercarp » Tue Apr 14, 2015 9:19 am
yes sir! all the bases are in, console, captains chair base, and cushions for my two front seats! The back order quandary on the rest of the cushions is not a huge deal. I still have a bit to work on before I am ready for the lake. The boy is heavy into baseball (tournament this weekend) so boat building time is limited.
Here is a question. With this new to me tank, will I have any problems mounting it "mid-ship"? Here is a diagram of where I am wanting to put the tank.
2015-03-28 17.45.39.jpg (199.57 KiB) Viewed 15679 times
#66 Post by curtiscapk » Tue Apr 14, 2015 9:33 am
is that going inside a seat base? If so I would vent it and you should be good I would think. I will let others chime in who have done it. Mine is under my sundeck.
Ercarp
#67 Post by Ercarp » Tue Apr 14, 2015 9:42 am
The tank came out of a bass boat. I will build a box for it to live in and vent it right out the side...possibly cut some vent holes in its cage as well. The only issue I can come up with, is the length of the fuel line. Will the engine fuel pump have enough "pump" to suck the fuel?
ToonGuy
#68 Post by ToonGuy » Tue Apr 14, 2015 10:49 am
Ercarp wrote:The tank came out of a bass boat. I will build a box for it to live in and vent it right out the side...possibly cut some vent holes in its cage as well. The only issue I can come up with, is the length of the fuel line. Will the engine fuel pump have enough "pump" to suck the fuel?
It will be fine :thumbsup
Hawk_308
#69 Post by Hawk_308 » Wed Apr 15, 2015 7:08 am
The motor should run with out a pump with the tank on the deck and the low profile of the jonson , once primed with a full tank fuel should siphon to the motor .
1988 24' Party Barge pushed by a 75hp cmc trim 17p 4 blade prop
Ercarp
#70 Post by Ercarp » Wed Apr 15, 2015 9:15 am
that is great to hear, thanks for the feedback curtiscapk, toonguy and hawk. I was concerned about that.
Ercarp
#71 Post by Ercarp » Wed Apr 29, 2015 1:59 pm
I am sure this has been asked before. I have tried to search for the answer, but thought I would ask. What is the thinnest aluminum you would use to underskin? I found a source to buy the sheets, but not sure how thick/thin to order.
ToonGuy
#72 Post by ToonGuy » Wed Apr 29, 2015 2:00 pm
Ercarp wrote:I am sure this has been asked before. I have tried to search for the answer, but thought I would ask. What is the thinnest aluminum you would use to underskin? I found a source to buy the sheets, but not sure how thick/thin to order.
The generally accepted thickness is .063
I have not personally tried anything thinner.
BobG
#73 Post by BobG » Thu Apr 30, 2015 9:17 am
I think I'm running .032 - it "oilcans" a little, but it's still good after 3 years!
Ercarp
#74 Post by Ercarp » Thu Apr 30, 2015 9:47 am
Thanks toonguy, that is the size I keep seeing. BobG, That is about the size I found and was wondering if it was too thin. How far apart are your floor "joists" (what is the span between the aluminum channel). Did you install the underskin yourself?
BobG
#75 Post by BobG » Thu Apr 30, 2015 12:14 pm
Ercarp wrote:Thanks toonguy, that is the size I keep seeing. BobG, That is about the size I found and was wondering if it was too thin. How far apart are your floor "joists" (what is the span between the aluminum channel). Did you install the underskin yourself?
Hmm... 24" I think, and yes I did. I think I used pop-rivets to install it.
