Sylvan RPT pontoons VS strakes on pontoons
UPTHECREEK
#1 Post by UPTHECREEK » Fri May 22, 2015 6:37 pm
Ok.... I'm still new at this and just doing my research. I know that the RPT pontoons are exclusive to Sylvan but how do they compare to all the other pontoon manufactures using strakes ? Are they better performers ? I know that I want one or the other on my new boat. I just don't want a traditional tube to push thru the water. Thanks and I hope this makes sense.
rdeterman
Re: Sylvan RPT pontoons VS strakes on pontoons
#2 Post by rdeterman » Fri May 22, 2015 7:14 pm
The RPT tubes work great. They are basically built in strakes and the boats plane off extremely fast. Everyone will have an opinion on this good or bad but I really like ours and ive driven quite a few different tri too setups.
2014 Sylvan Signature 8523 LZ
2014 Yamaha F200 2.8l
Iowa
UPTHECREEK
#3 Post by UPTHECREEK » Fri May 22, 2015 7:23 pm
rdeterman wrote:The RPT tubes work great. They are basically built in strakes and the boats plane off extremely fast. Everyone will have an opinion on this good or bad but I really like ours and ive driven quite a few different tri too setups.
Thanks Rdeterman ..... We may check out a Sylvan dealer tomorrow. Is your model a twin toon or tri ? I'm assuming you have a pretty big pontoon running a 200.
pond tuuunes
#4 Post by pond tuuunes » Fri May 22, 2015 7:55 pm
I havnt seen any pics of them, but if tbey are like strakes but formed into the toon, vs welded on that would be much better, every fall I have to take my toon to a welder to get the cracked welds on the strakes repaired. JT
#5 Post by Bamaman » Fri May 22, 2015 10:05 pm
Sylvan had a bunch of problems with the structure of the RPT toons. I honestly thought that they'd been withdrawn from the market. I was thinking they perform well, but I wouldn't want to risk spending so much money on a boat that has had so many past problems.
Just give me a good ole tritoon with lifting strakes and a big motor. They're tried and true--and perform very well.
rdeterman
#6 Post by rdeterman » Sat May 23, 2015 6:30 am
Its a Tritoon
Iowa
rdeterman
#7 Post by rdeterman » Sat May 23, 2015 6:33 am
Bamaman wrote:Sylvan had a bunch of problems with the structure of the RPT toons. I honestly thought that they'd been withdrawn from the market. I was thinking they perform well, but I wouldn't want to risk spending so much money on a boat that has had so many past problems.
that was true in years back. pre 2012. All the newer ones are newly designed. Ours has the new 2.0 verison and I have not heard of any failures.
https://youtu.be/yBbym1wkNoI
Iowa
UPTHECREEK
#8 Post by UPTHECREEK » Sat May 23, 2015 8:59 am
[quote="rdeterman"
https://youtu.be/yBbym1wkNoI[/quote]
Rdeterman is your Sylvan 2 or 3 toon ? How's it perform with the Yamaha 200 ? Thanks
rdeterman
#9 Post by rdeterman » Sat May 23, 2015 1:25 pm
Its a Tritoon. The Yamaha 4 cylinder 200 is a great motor. It puts the boat right on plane and top speed is 42-43mph. Its also very efficient and quite.
Iowa
#10 Post by RcgTexas » Sat May 23, 2015 5:42 pm
UPTHECREEK wrote:[quote="rdeterman"
That's a good looking pontoon in the video. I built my center toon much the same way. The bottom of my center log is flat though and really speeds planning.
Kramfam
#11 Post by Kramfam » Sat May 23, 2015 7:59 pm
I have a new Sylvan with the RPT tubes and have no complaints so far. I previously had a ski boat and was worried about handling...I've been impressed with the handling so far. Given that i have two tubes I'm going to credit the RPT design for that.
I boat on a very large, rough lake and also like that the RPT tubes are 27"s. Very stable in rough water.
27" RPT tubes w/underskinning
2014 115hp Mercury 4 stroke
ToonGuy
#12 Post by ToonGuy » Tue May 26, 2015 7:12 am
I believe most of the issues were due to the "M" style mounting brackets. There were a few issues with nose cones, but nothing major and probably not even worth mentioning. Sylvan has switched to a continuous outside riser (among other changes) and as far as I know this eliminated the issues they had with leaking tubes.
flossy2150
#13 Post by flossy2150 » Tue May 26, 2015 10:55 am
I have a 2015 Sylvan with RPT PR25 package and a 150 Yamaha. My top end is about 36-38 mph with 3-5 people and gear. I could maybe get a bit more out of it as I learn and get a better feel for the trim vs. RPM.
I need to get my prop info but it looks to be a stainless prop.
I've been pleased so far but this is my first "real" power boat.
It turns very well and feels stable in the turn.
2015 Sylvan Mirage Cruise 8522 LES RPT PR25 Package
Outboard: Yamaha F150XA
Prop: Solas "New Saturn" 3531-145-15 (Stainless Steel, 3 blade, 14.5" diameter, 15" pitch)
UPTHECREEK
#14 Post by UPTHECREEK » Tue May 26, 2015 7:11 pm
flossy2150 wrote:I have a 2015 Sylvan with RPT PR25 package and a 150 Yamaha. My top end is about 36-38 mph with 3-5 people and gear. I could maybe get a bit more out of it as I learn and get a better feel for the trim vs. RPM.
Flossy your boat sounds great.......do have any pics you could share ??
hypnoj
#15 Post by hypnoj » Tue May 26, 2015 7:27 pm
Honestly, the best thing you can do is get out and drive them. Don't sit back and hope there is a difference; make sure there is. I think all pontoon boat owners like their boats, but I was amazed at the difference in all of them when test driven. In fact it seemed that no two companies even felt the same. My wife and I were lucky enough to happen upon an on-water boat show, so we were able to test drive several different companies and boats in one day. Unfortunately, Sylvan was not at that show, or we would have tried one on for size.
Bi-toons felt much different from tritoons, and full length center tritoons felt much different from sporty/short center tritoons. Harris has a lowered middle toon on their tritoons; which felt different then those with all 3 toons the same height. Some had lifting strakes on the outside toons; some only had strakes on the inside. I'm not going to tell you what I thought about all of these (unless you really want me to) because it's important for you to feel the difference.
