Tires 1 year old on trailer dry rot ???
jwachevy
#1 Post by jwachevy » Sat Jun 20, 2015 5:10 pm
Purchased a Southbay pontoon last year with a tandem
Axle Baer trailer and the tires are already dry rotting
Is this normal ???? Trailer has 500 miles on it
[color=#0040FF]2014 Southbay 22 footer
Keep in water all year
Lake Jacomo
Restricted lake 40hp max
Wrapped toons[/color]
[color=#0000FF]2015 GMC Yukon Denail[/color]
Heatman
Re: Tires 1 year old on trailer dry rot ???
#2 Post by Heatman » Sat Jun 20, 2015 5:53 pm
no. Sold my 10 year old boat and trailer with the original tires on it. Never a problem.
Sheridan, Indiana
#3 Post by RcgTexas » Sat Jun 20, 2015 6:37 pm
ITs the sun! The mileage has nothing to do with it unless they are worn out.
BoatCop
#4 Post by BoatCop » Sat Jun 20, 2015 6:56 pm
Check the date code. Just cause they're new to you doesn't mean that they weren't sitting on a shelf for a few years before you got them.
It'll start with "DOT" and end with 4 digits. The first 1 or 2 are the week they were made and the last 2 are the year.
DOT XXX XXX2613 means the tire was made the 26th week of 2013.
Alan
2016 Chevy Tahoe
2009 GMC Sierra
2001 Jeep TJ Wrangler
1999 Southwind 34L MH
2 little Basset Hounds
rdeterman
#5 Post by rdeterman » Sat Jun 20, 2015 7:09 pm
My front 2 on my trailer did the same things in less than a year. Call the trailer manufacture and complain.. I did and have 4 new ones sitting in my garage right now.
2014 Sylvan Signature 8523 LZ
2014 Yamaha F200 2.8l
Iowa
jwachevy
#6 Post by jwachevy » Sat Jun 20, 2015 7:20 pm
Would I have better luck with the place I bought the boat ??
Rather than the trailer mfg
What's a good tire to replace these with??
Lake Jacomo
C_M_25
#7 Post by C_M_25 » Sat Jun 20, 2015 8:05 pm
Mine did the same thing. It was chalked up to a manufacturing defect (chinese tire syndrom) and were replaced with 2 new ones. They are still going strong to this day.
2014 Sweetwater 2086SW
90 Hp Yamaha 4-stroke
#8 Post by Bamaman » Sat Jun 20, 2015 9:13 pm
jwachevy wrote:Would I have better luck with the place I bought the boat ??
It depends on the size of the tires. If they're 13", you'd best go with Maxxis M8008's. If 14", Maxxis or Kumho 857's. Avoid any Chinese built tire like the plague.
Another option would to use a high quality auto/truck tire and pump'em up to max air pressure. You'd have to check and see if their weight rating is equal to your boat & trailer weights, however.
LadyGT
#9 Post by LadyGT » Sun Jun 21, 2015 12:59 am
As previous posts have said, check the codes on the tires. Tires are only supposed to last 7 years max, more if you keep them out of the sun. Any tire store can help you verify the codes. Go back to the dealer where boat was purchased and complain. Tires are about $100 plus to replace. You should consider having a spare too.
We have a 30' travel trailer and the same thing happened to us when we bought it. All 5 tires were replaced by the RV dealer. All we had to do was send in pics of the tires and find a way to get the tires on the rims ourselves. Your tires should be under some sort of warranty.
What is the brand of tire that you have problems with? I want to compare with ours to be on the safe side.
Denise and Jim
2001 Ford F250 Turbo Diesel
STEVEBRENDA
#10 Post by STEVEBRENDA » Mon Jun 22, 2015 9:07 am
I have never known anyone that has used auto/truck tires on a trailer and been happy. The sidewalls are not heavy enough and therefore do not handle well.
2014 Regency 254
Mercury 250L Verado
#11 Post by Bryden24shp » Tue Jun 23, 2015 5:49 am
When my trailers sat outside (before the boat port and now the shed) I always covered my tires with vinyl tire covers. I got a bunch when I was the service manager at the Jeep dealership in town after they had a major spare tire recall a few years ago. They said to just slice them up and throw them away. Hell no! I could use them! A P-metric tire won't last 10 miles on a boat trailer You need at least a 6 ply side wall. My Hoosier had 8's and the old Clarks for my Baja's and the Heritage I have now, are all 10 plys.
Cowracer
#12 Post by Cowracer » Tue Jun 23, 2015 12:32 pm
Google "China bomb trailer tires" for hours of enlightenment.
Tim
jwachevy
#13 Post by jwachevy » Tue Jun 23, 2015 8:56 pm
Ok the tires are "Trail American "
Sent pix to dealer no word yet!!
Here's the best tire
Lake Jacomo
C_M_25
#14 Post by C_M_25 » Wed Jun 24, 2015 4:56 am
That picture looks exactly like the one I posted almost a year ago. Same exact tire, rim, and damage. I'm sure that you'll get a set of new tires.
LadyGT
#15 Post by LadyGT » Wed Jun 24, 2015 6:11 am
I passed the info learned here to my husband and he said our RV tires were not even a year old when he saw cracks like those in the pics.
I Googled China bomb tires and the info was old. Is there a list of tires to avoid? I also read online that RV tires should not go over 65 mph? We drive 70 here because that is the limit. Does it really make a difference?
Denise and Jim
