Fun-Toon
Luke
Re: Fun-Toon
#31 Post by Luke » Wed Jun 17, 2015 1:28 pm
Probably the first time Fun-Toon has been out of the water in several years
2015-06-17 16.23.55.jpg (1.92 MiB) Viewed 8343 times
Luke
Re: Fun-Toon
#32 Post by Luke » Wed Jun 17, 2015 1:34 pm
ron nh wrote:The water is so clear it looks like its floating. well I guess it is floating but looks like its in air.
I know right. The front barely touches the water and when a few of us sit out back it picks the front up out of the water.
This old boat probably wasn't intended to have a Mercury 115 strapped to the back
Luke
Re: Fun-Toon
#33 Post by Luke » Thu Jun 18, 2015 3:03 pm
Got the front roof on today. I'm really pleased with it overall and plan to do more to it
2015-06-18 17.32.39.jpg (1.71 MiB) Viewed 8285 times
willy13
Re: Fun-Toon
#34 Post by willy13 » Fri Jun 19, 2015 6:42 am
Looking good!!!
Luke
Re: Fun-Toon
#35 Post by Luke » Sat Jun 20, 2015 3:17 pm
Thank you, I think so too. Really changes things
Luke
Re: Fun-Toon
#36 Post by Luke » Sat Jun 20, 2015 8:28 pm
The donor boat had a 40 hp Force with a tachometer. Will this tach work on my Mercury 115?
Luke
Re: Fun-Toon
#37 Post by Luke » Thu Jun 25, 2015 8:37 am
Welding the transom to the 3rd toon :nana
2015-06-25 11.32.44.jpg (1.19 MiB) Viewed 8139 times
willy13
Re: Fun-Toon
#38 Post by willy13 » Fri Jun 26, 2015 6:31 am
Thanks for the update!
Do you know the weight of that 3rd pontoon?
Luke
Re: Fun-Toon
#39 Post by Luke » Fri Jun 26, 2015 8:26 am
willy13 wrote:Thanks for the update!
I don't know the weight of it but I'm guessing it is pretty close to the same weight as the other two as they are close to the same size. Why do you ask?
Luke
Re: Fun-Toon
#40 Post by Luke » Sat Jun 27, 2015 11:27 am
My Welder is having a terrible time sealing all of the pin holes. It looks like I'm going to have to take it to someone else to fix the pin holes. Any suggestions?
Luke
Re: Fun-Toon
#41 Post by Luke » Sat Jun 27, 2015 7:26 pm
3rd toon is in bit has several pin hole leaks around new welds. I'm going to try to find a Welder on Monday who is more experienced with welding on old pontoons
2015-06-27 22.13.22.jpg (1.6 MiB) Viewed 8033 times
Luke
Re: Fun-Toon
#42 Post by Luke » Sat Jun 27, 2015 7:30 pm
:donno
2015-06-27 22.12.29.jpg (1.6 MiB) Viewed 8032 times
Luke
Re: Fun-Toon
#43 Post by Luke » Sat Jun 27, 2015 7:34 pm
:paranoid
2015-06-27 22.11.47.jpg (1.59 MiB) Viewed 8029 times
Luke
Re: Fun-Toon
#44 Post by Luke » Sat Jun 27, 2015 7:38 pm
:alright
2015-06-27 22.13.58.jpg (1.36 MiB) Viewed 8019 times
Re: Fun-Toon
#45 Post by RcgTexas » Sun Jun 28, 2015 8:41 pm
The older aluminum can be a pain to weld on. Especially aluminum that has been in salt water. the thickness is also a problem. TIG might be a better choice than a MIG.
