I'm looking for information ? I have a Evinrude E-tec 40hp on a 22ft
Southbay. I've had it a year. It has burned 2 GALLONS of oil at the 35 hour
Mark, I've read on Evinrude Nation it's normal and I've read it's not.
Anyone have experience on this??
2015 Evinrude E-Tec Burning Oil
[color=#0040FF]2014 Southbay 22 footer
Keep in water all year
Lake Jacomo
Restricted lake 40hp max
Wrapped toons[/color]
[color=#0000FF]2015 GMC Yukon Denail[/color]
Lake Jacomo
- rancherlee
Re: 2015 Evinrude E-Tec Burning Oil
Seem about right considering double oil break-in and figure 1 gallon per 50-75 gallons of gas burnt.
I run mine at 100/1 and it is right on
They burn considerably more during breakin. What oil was your outboard setup for by the dealer? I assume the 40 hp motors can be setup to run XD30 50 or 100. If programmed for XD100 they obviously use much less oil.
Spend time at Nolin Lake, KY
2 strokes are suppose to burn oil.
But seriously that sounds correct.
- rhorne
That sure is a lot of boat for a 40hp motor. Could you possibly be putting to much strain on the motor? I'm just throwing this out there. Good luck. Love Etec.jwachevy wrote:I'm looking for information ? I have a Evinrude E-tec 40hp on a 22ft
[b]If you can read this thank a teacher.
If you are reading it in English thank a Veteran.[/b]
2014 Tahoe LT Cruise 2300
2014 Evinrude Etec 250 HO
2008 Stratos 294 XL
2012 Evinrude Etec 225 HO
2008 Stratos 294 XL
Now that you've got some hours on the motor, it's time to document your fuel usage vs. oil usage. Keep some good records in the near future and regroup after you have exact information on your boat's performance. Without specifics, it's hard to tell where you stand.
Good thing is that you have a good, long warranty.
