Grease for new prop?
Whitehorse
#1 Post by Whitehorse » Mon Jul 13, 2015 12:51 pm
Our prop got a bit dinged up over the weekend so I was going to put on the spare we have. Looked at a couple videos online to make sure I wouldn't miss doing something obvious and saw that they all were using marine grease on the shaft before putting the new one on.
Do I need to use that? I don't have any at home right now, the closest thing I have is anti-seize.
2001 Suntracker Party Barge 21
90hp 2 Stroke Merc
Figuring it out as we go!
babock
Re: Grease for new prop?
#2 Post by babock » Mon Jul 13, 2015 2:44 pm
Don't use anti seize.
Mercury 90 4 stroke
#3 Post by lakerunner » Mon Jul 13, 2015 7:03 pm
I use white lithium grease. It wont hurt to do it later. I have seen props almost welded to shaft from never removing and lubing shaft
rancherlee
#4 Post by rancherlee » Wed Jul 15, 2015 5:07 am
lakerunner wrote:I use white lithium grease. It wont hurt to do it later. I have seen props almost welded to shaft from never removing and lubing shaft
that's the exact reason for the grease, Never Seize is usually copper based which can cause electrolysis issues, especially if ever used in salt water. As long as there is still some grease on the shaft I leave it alone, I don't put fresh stuff on with every prop swap.
RobZ71LM7
#5 Post by RobZ71LM7 » Wed Jul 15, 2015 6:18 am
Just use grease, but you may find a aluminum complex is better than a lithium complex in dealing with water.
Spend time at Nolin Lake, KY
Whitehorse
#6 Post by Whitehorse » Wed Jul 15, 2015 9:10 am
Thanks everyone. I went to the only nearby marine repair place on my way back from work and got a tube of marine grease for $9.
90hp 2 Stroke Merc
robertm
#7 Post by robertm » Wed Jul 15, 2015 9:56 am
Here's what I used. Working well so far:
2-4-C Marine Lubericant W/Teflon 8Oz Made my Mercury
http://www.amazon.com/gp/product/B001HW ... detailpage
'Miss Kelley'
Yamaha F200 LB
14.5" X 15P SS Reliance
2015 Ram 1500 Eco Diesel
BobG
#8 Post by BobG » Wed Jul 15, 2015 11:03 am
robertm wrote:Here's what I used. Working well so far:
Well, you would HOPE that it works, as that's exactly what Mercury recommends! :lol3
