Filling gas tank problems
creel
#1 Post by creel » Thu Jul 30, 2015 6:09 pm
Hello!
I'm attempting to fill my boat on the trailer using 5-gallon gas cans and one of those shaker siphons. I can get the siphon going no problem, but after a few seconds, gas will start coming out of the fill spout as I am filling it. I made sure that the siphon hose was inserted all the way. I tried again, and got the same result.
I looked inside the fill spout (on the side of my boat) and I can see some sort of metal tip with a hole in it sticking across the inside of the fill tube -- about 3 inches in. I think that the gas is hitting that as I am filling and it is running back out slowly. I can fill the tank with a funnel and pouring rreeaallyy slowly but that is a pain.
What is the best way to do this??
Thank you!
2015 Avalon LSZ 2085
sunedog
Re: Filling gas tank problems
#2 Post by sunedog » Tue Aug 04, 2015 10:06 am
Sorry, I don't have any answer for you. Just bumping back to the top. I use a Wonder Pump shaker hose every single weekend and have no problems with it.
OK Toon
#3 Post by OK Toon » Tue Aug 04, 2015 1:17 pm
No idea what that might be -- doesn't seem useful because using a jiggle hose or filling from a fuel pump, would cause gas to splash back out. I know my fill spout doesn't have anything like that since I just pulled the tank out last weekend to completely empty it and check the tube that pulls gas out to the fuel line to the motor. I was looking down in that fill spout with nothing blocking the view.
Hopefully somebody might have a suggestion for you.
#4 Post by lakerunner » Thu Aug 06, 2015 8:26 am
Is your vent a part of fill tube? If so you might be closing it off causing fuel to back up
creel
#5 Post by creel » Fri Aug 07, 2015 7:22 am
lakerunner wrote:Is your vent a part of fill tube? If so you might be closing it off causing fuel to back up
It is. My 'toon has an "Enviro-Fill" gas tank and the way the venting is designed is awful. I contacted Avalon about the issue and the company that makes the gas tank makes a manual fill aid aka a special funnel that they are sending me for free. The funnel supposedly sits in the fill tube just right to prevent the back spray I am getting. I hope this will fix the issue.
#6 Post by lakerunner » Fri Aug 07, 2015 12:49 pm
Excellent
smltooner
#7 Post by smltooner » Fri Aug 07, 2015 2:53 pm
I'm glad the company is sending you the funnel. Since they know there is a problem, it seems to me that they would provide the funnel with each new boat to prevent this problem.
SMLTOONER
Ted & Emily
2019 Bennington 21SL Tri-toon
2019 Yamaha 150 HP
Smith Mtn. Lake, Virginia
Seon
#8 Post by Seon » Fri Aug 07, 2015 6:49 pm
creel wrote:.. aka a special funnel that they are sending me for free...
They're not doing you any favor...as mentioned, they should have provided that when you bought your Toon :nono .
Glad all is good :thumbsup .
1989 28' Tracker Party Hut
115 hp 4 stroke Yamaha
Sacramento, Ca
