New Tritoon and new member.
lozcruisin
#1 Post by lozcruisin » Fri Aug 21, 2015 7:46 am
Hey All,
I'm a new member and was asked to post a few pic's of my Tritoon. It is a 2008 Sunset Bay Cruz 250 with a Mercury Optimax 150 HP and as you can see double bimini's too. Here they are the pic's..... I am starting to plan for underskin for my Tritoon and am looking for advice. I am considering .063 aluminum sheets as my cross members are 24" on center. Has anyone used .040 for underskinning with 24" centers? Thanks.
20150728_182605 (Copy).jpg (244.14 KiB) Viewed 2787 times
20150728_182505 (Copy).jpg (130.82 KiB) Viewed 2787 times
20150728_182522 (Copy).jpg (307.82 KiB) Viewed 2789 times
Regards,
Ken
Strake
Re: New Tritoon and new member.
#2 Post by Strake » Fri Aug 21, 2015 9:35 am
Welcome to the Club !!!!
I would think you would be perfectly fine with .040" for under skinning as it's keeping the splash water off and not really much for structural rigidity. It would also be a lot easier to work with. A 5052 H32 alloy is considered "half hard" and you can form it. Don't get 6061-T6 as that is not going to bend well.
Enjoy :thumbsup :thumbsup :thumbsup
"Strake"
Richard and Angie
Smith Mountain Lake, VA
2015 Berkshire 233 RFX STS
Yamaha F200 LB
#3 Post by curtiscapk » Fri Aug 21, 2015 11:41 am
Wow looks brand new!
PlaynDoc
#4 Post by PlaynDoc » Fri Aug 21, 2015 12:34 pm
Welcome... nice ride
smltooner
#5 Post by smltooner » Fri Aug 21, 2015 12:53 pm
Welcome to the club.
SMLTOONER
Ted & Emily
2019 Bennington 21SL Tri-toon
2019 Yamaha 150 HP
Smith Mtn. Lake, Virginia
pond tuuunes
#6 Post by pond tuuunes » Fri Aug 21, 2015 3:20 pm
Nice Tuuune!
rancherlee
#7 Post by rancherlee » Sat Aug 22, 2015 5:29 am
I would think .040 would be plenty, I have some .063 under mine and its overkill on 24" centers but I got it cheap so I used that along with an old truck bed liner.
#8 Post by Bryden24shp » Sat Aug 22, 2015 7:09 pm
Nice boat! And welcome to the forum! You're at that best place to be! But the newest members have to start the coffee in the morning! No de-caf for me!
lozcruisin
#9 Post by lozcruisin » Sun Aug 23, 2015 4:54 pm
Thanks for the welcome and the advice. I think .040 might just do the job as the width is only 27" between the logs in my tritoon. I am thinking of bending a 6" angle on either side for rigidity and using self tapping SS screws also. Any other thoughts?
Regards,
Ken
#10 Post by Bryden24shp » Mon Aug 24, 2015 5:21 am
Self tappers work good, especially if you need to remove the panels, in the future to run wiring or something. One quick hint is to run a conduit with dead wires through it before you skin it, if you plan on adding any electronics in the future. It helps. I had to remove the underskinning on my old boat twice, once to add my Jackplate, and then again to add an amp. They should do this from the factory on new boats. Have them pre-wired. It has been mentioned to a few reps in the past.
