Do I need Amp/Sub
homey
Do I need Amp/Sub
#1 Post by homey » Sun Aug 23, 2015 2:29 pm
On my Harris cruiser I upgraded to a Kenwood HU with 4 Polk DB651. Night and day difference between this and the factory Seaworthy 2 speaker setup.
I am in the process of buying a second battery for my pontoon to isolate all electronics. Was curious if buying a amp and/or sub would help much? I listen mostly to classic rock and blues (no rap on my boat!). Hear good things about the Clarion Xc-1410 50RMSx4 amp. I don't listen loud much but was curious if an amp would bring out more highs and clarity to the music. I don't need thumping bass but was curious if adding a sub and running an amp on lowpass would help overall.
2011 Harris Floteboat CX 200 Cruiser
2002 Yamaha 800XLT
Drago
Re: Do I need Amp/Sub
#2 Post by Drago » Sun Aug 23, 2015 6:43 pm
Unable to find specs on your new radio but our Kenwood marine radio benefited nicely with the addition of http://www.amazon.com/Sony-XM604M-Marin ... B000N3VFN0
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
Xscash
#3 Post by Xscash » Mon Aug 24, 2015 4:38 am
The only way an amp would help is if the speakers are rated for 50% more power than the head unit can deliver. I would advise against it. If you added separates with mids and tweeters and a crossover then yes. you don't really need a second battery, just a good interstate high reserve single battery will do. I have 3 amps 8 speakers and a 12" sub running on 1 battery and we park for 8hrs on a sat with the music on all day. Add a solar charger on the anchor pole and connect it to the battery so it fills it with free power while the boat is sitting all week.
rancherlee
#4 Post by rancherlee » Mon Aug 24, 2015 6:42 am
An amp helps a ton, I actually JUST run an amp and connect it directly to my IPhone with a headphone to RCA Y cable. I have a pair of those Polk 6.5" and feed them with 60wrms from an old MTX (USA built) car amp in the console. Previously I had a Kenwood marine deck and it had nowhere near enough power for CLEAN FULL sound at cruising speed. I'd say no on a Subwoofer though, bass travels a long way on water and it takes a ton of power to get meaningful bass in an open air environment.
homey
#5 Post by homey » Mon Aug 24, 2015 3:02 pm
Thanks for all the good info. I couldn't find much info on subs and see why now. Will try a small amp to see if it brings the speakers to life. Speakers are rated for 60RMS and HU is only providing 22 RMS.
2002 Yamaha 800XLT
garygve
#6 Post by garygve » Mon Aug 24, 2015 7:03 pm
I installed the Polk PAD 5005-5 amp on my Harris pontoon with the Polk speakers. Its a marine amp and has a sub woofer output I bought it on ebay for $255. It has great sound and I put one of my sons extra sub woofer speaker box under the helm its not very loud under the helm but has a nice bass if you want it. Whats nice about the amp is it has a volume control switch that I mounted on the dash with 2 sided tape and I can adjust the sub woofer bass as desired.
150 Mercury 4-stroke
ron nh
#7 Post by ron nh » Tue Aug 25, 2015 11:40 am
When I ordered mine I upgraded to 6 speaker system with a built in amp. I assumed I would still have to tinker with it, but it's sweet. the loader it gets the more clear it is. I'm going to skip the sub even though my :nana kids want it for jungle thumpin.
LittleRiver
#8 Post by LittleRiver » Thu Aug 27, 2015 7:17 pm
Amp will make a world of difference especially when running.
Kicker 1100 rms on mine and I use a honda 1000eu generator when i'm parked thats keeps the three bank battery charger going. Its like 35 amps per bank so the stereo don't run the battery down.
If your into music, i'd always run a amp. If its not that important don't. Simple answer to that equation.
[i][color=#0000BF] ...08 24' Party Barge "Tiggers Toy" 50hp..[/color][/i]
[i][color=#0000BF] ..Triton TR21X 250 V-Max "Yellow Bullet".. [/color][/i]
[i][color=#0000BF] .. Little River Motorsports Top Dragster T/D[/color][/i]
[i][color=#0000BF] ..Dodge and Ford truck, but still race a Chevy[/color][/i]
brianD
Location: Live in STL, Boat wherever there's enough water to not mess up a prop.
#9 Post by brianD » Thu Aug 27, 2015 8:19 pm
I added the MB Quart 710.5 and a 10 inch sub from them as well. BEST THING EVER!! Really brought life to my Sony 5's and my Bazooka tubbies mounted on my ski bar. Sooo much less distortion. Improved clarity especially when running. Even sounds better at lower volumes. Do it!
b
2006 Landau Excalibur 2700
225 Suzuki 4 stroke
2011 Bear tandem trailer
2011 3/4 ton Suburban
