tracker pontoon trailer loading guides
MOHAVEMAN1
Hello to everyone I have a 2011 Party Barge 24 (26 feet long) and want to install loading guides attached to rear of trailer to help when windy, as it seems to be everytime I go out. Any suggestions on style and type and pics would be great. Tracker trailers at least mine does have the long inside guide rail a 2 x4 from factory but its about 5 or 6 feet from end of trailer and everytime i load toon the logs get of out of grooves where logs sit and logs are are not resting on long rails. I hope by adding guides this will bring boat right in and perfectly aligned every time and not have to back in and out on ramp trying to get toons sitting properly on rails. Gets old having to get in water at end of trailer and pushing on toons on direction or the other as wife pulls out boat. Boat is securly fasten with winch at front of trailer and front part of toons in the rails but the logs at rear is out of rails.
Thanks for any suggestions 53 Powell
Gonefishing
Re: tracker pontoon trailer loading guides
Check this company out for what you are looking for. Got mine about two years ago Ordered a set took about an hour by myself to install. Would not be without them now. As you said loading in the winds is a pain and always took the fun of a day boating away when I returned to the ramp to load up. With these I load by my self and have loaded in winds over 15 mph. They are great. http://www.4c-innovations.com/. Don't know why every pontoon company doesn't put this on their trailer to start with. Pm me with questions if you like.
Bob Jacksonville, Nc
2013 Excursion X23 RFC
2013 115 Yamaha
Pulled with a Ford King Ranch
2013 115 Yamaha
- Rrr Happy Place
2014 Dodge Ram Eco diesel
2016 South Bay 522 CR 3.0 salt water edition tri toon with full enclosure 115 Mercury 4 Stroke
MOHAVEMAN1
Tnx for info i will ck it out
- lakerunner696
you could find a welder and have him make a L from 2" angle and get U bolts to attach to trailer. Then just add 2 2X6 for guide. Also move guides close to logs
2008 F150 Lariat Super Crew
Haul Rite trailer
Haul Rite trailer
There is an entire ride-up on the 4C Innovations Bunk Guide System in the Manufacturer Review section with various other ideas.
2011 Tundra
2011 Tundra
53Powell... don't know if this is what you are referring to, but I added these trailer guides to my rig and it helped tremendously...makes it much easier to line up when loading..
- 100_0955.JPG (288.05 KiB) Viewed 9035 times
- 100_0953.JPG (323.23 KiB) Viewed 9038 times
53Powell, I feel your pain. I, too, am considering guides for when I launch in moving water/wind. But I'm leaning more toward external guides like Roland did, primarily because I ultimately want to add the pontoon water glide underneath. (http://www.pontoonwaterglide.com/index.asp)
In the meantime, I learned not to back my trailer as far into the water as I used to do for v-hulls. I leave a good third of the trailer out of the water and use the throttle to drive the toon up onto it. Obviously, if you use a really shallow ramp where your motor has to be raised to load, that technique won't work. And even when it does, I've smacked the pontoon uprights really hard a couple of times until I got the hang of it. But when enough of the toons are in the bunks, it stays straight.
Bill & Maggi - Hudson, Fl.
2013 Avalon LS 25' Party Barge
2015 Evinrude eTec 135 H.O.
2001 Ford F350 SuperDuty Lariat XLT Dually 4x4
Crewcab Longbed w/ 7.3 ltr Turbo Diesel
2004 R-Vision 30' Fifth Wheel Camper
Gonefishing
I don't think you will find anything that works better then the 4c in my prior post. Was the best money I ever spent. I now load my toon with ease in the wind or rough water no matter.
2013 115 Yamaha
2013 115 Yamaha
I just received the kit from 4C Innovations. Will be installing next weekend.
Has anyone done a tri-toon installation and if so do you have any pictures?
Yamaha 150 4 stroke
GPS 39 mph 4 adults full fuel
2016 Yamaha FX Cruiser HO
Lake Anna, VA
Yamaha 150 4 stroke
Lake Anna, VA
Gonefishing
Budoff,
I don't have three toons but I do know if you have any questions give them a call. They are very good to deal with n will take the time to answer any questions you may have. I had questions called them n they returned my call n took the time to answer everything I had.
2013 115 Yamaha
2013 115 Yamaha
Bob,
Did you get the auto-latching kit with it also? If so, how do you like that feature?
Melanie
Melanie
2001 Riviera Cruiser Regatta 2525
1985 Harris Flotebote Heritage 240
1994 Playbuoy Challenger 20 DLX
Deep Creek Lake, MD
Deep Creek Lake, MD
Gonefishing
No I didn't get the locking feature; however, I am thinking of order it next year. I do love the loading system for sure. No more problems with wind or the boaters who don't know what a no wake zone is when loading.Mel85CJ wrote:Bob,
Melanie
2013 115 Yamaha
2013 115 Yamaha
