Adhesive Removal.....
OK... Had to remove the "old" numbers on my toon, and the numbers and state sticker left a lot of adhesive behind. Used a bunch of "Goof-Off" with minimal results. This is on the painted "black" side panels. Acetone and Lacquer Thinner of course are out. WD-40, Mineral Spirits/Paint Thinner? What do you suggest?
Thanks in advance!!
Sami
Thanks in advance!!
Sami
- LittleRiver
Re: Adhesive Removal.....
gas....... simple, quick, effective.
[i][color=#0000BF] ...08 24' Party Barge "Tiggers Toy" 50hp..[/color][/i]
[i][color=#0000BF] ..Triton TR21X 250 V-Max "Yellow Bullet".. [/color][/i]
[i][color=#0000BF] .. Little River Motorsports Top Dragster T/D[/color][/i]
[i][color=#0000BF] ..Dodge and Ford truck, but still race a Chevy[/color][/i]
WD 40, works wonders.
2011 Tundra
2011 Tundra
#2.... not that kind of #2.... #2 on the WD40...
- rancherlee
WD-40 or a Heat gun set to low have worked for me. I used a combo of both when I removed all the factory graphics on my resto!
I've always had good luck with Mineral Spirits, Napata etc... WD40 works good and I also really like Brake Cleaner too.... If not an extreamly old weathered sticker a Heat Gun works like a champ...
3M adhesive remover is night and day better than goo-gone.
http://www.amazon.com/3M-03618-Adhesive ... ve+remover
'Miss Kelley'
Yamaha F200 LB
14.5" X 15P SS Reliance
2015 Ram 1500 Eco Diesel
Yamaha F200 LB
UPDATE!! Had some WD-40 handy, so I tried that. Worked like a champ! (Had the gas can out if that didn't work.....plus a fire extinguisher!!) Really appreciate all the input and help. Hope to get this bad boy in the water soon!
Thanks!
Sami
Thanks!
Sami
SamiGuy wrote:UPDATE!! Had some WD-40 handy, so I tried that. Worked like a champ! (Had the gas can out if that didn't work.....plus a fire extinguisher!!) Really appreciate all the input and help. Hope to get this bad boy in the water soon!
Thanks!
Sami
yeah, it's always best to try WD-40 before using gasoline and matches... sure glad you had the extinguisher handy!
RonKMiller
Solvents?
You guys are working (and sniffing) WAY too hard.
Next time turn a nightmare job into 30 seconds and be DONE:
http://www.ebay.com/itm/ABN-Pinstripe-D ... 1723839028
