Installing a water separator
brianD
Location: Live in STL, Boat wherever there's enough water to not mess up a prop.
#1 Post by brianD » Sun Apr 03, 2016 2:39 pm
Hey all,
I'm looking to install a water separating fuel filter on my toon and need some advise:
I have a 225 suzuki and my gas tank is topside, port side. The fuel line of course is at the bottom of the tank and runs through the aluminum to the motor area.
1. Should I mount it above the deck where the fuel like will go up before going down to the primer bulb
2. Should I mount it at deck level at the top of the splash well so the fuel line goes down, but the filter is close to the water and might get wet
My concern is creating a siphon/no fuel situation mounting it high, or water intrusion to the filter if I mount it low.
Any thoughts??
b
b
2006 Landau Excalibur 2700
225 Suzuki 4 stroke
2011 Bear tandem trailer
2011 3/4 ton Suburban
ralph
Re: Installing a water separator
#2 Post by ralph » Sun Apr 03, 2016 6:33 pm
Mine is located just on the portside of the OB by the splashwell, about deck level. No problems where it is located at all. Actually it's very easy to change when the boat is on the trailer. Sure it probably gets wet but they have a seal just like an oil filter. No water gets in.
2015 90 HP Yamaha
2017 4WD GMC Canyon
teecro
#3 Post by teecro » Sun Apr 03, 2016 6:49 pm
ralph wrote:Mine is located just on the portside of the OB by the splashwell, about deck level. No problems where it is located at all. Actually it's very easy to change when the boat is on the trailer. Sure it probably gets wet but they have a seal just like an oil filter. No water gets in.
Heck on currently made Sun Trackers the fuel tank is in the motor pod which is hung under the boat. The motor pod is an open ended canoe, thus the tank is IN the water anytime the boat is IN the water. Many times while underway there is water rushing over the top of the tank and there is no water intrusion.
Mount the filter unit where it is easy to servise...
jafo9
#4 Post by jafo9 » Tue Apr 05, 2016 5:45 am
teecro wrote:Mount the filter unit where it is easy to servise...
agree. also, don't forget to oil the seals before you install. helps a ton when changing the filter.
2002 MasterCraft X30
2007 Yamaha FX HO Cruiser
2005 Kawasaki SXR800
2004 Yamaha SuperJet
1989 Kawasaki 650sx
Lewis Smith Lake, Alabama
brianD
#5 Post by brianD » Thu Apr 07, 2016 6:47 pm
Thanks guys. I will fabricate a mount to keep I just above deck level by the splash well. I appreciate the feedback
b
225 Suzuki 4 stroke
#6 Post by Bryden24shp » Fri Apr 08, 2016 10:25 am
Here's a pic of mine on the Premier. I have an open transom, with fuel tank mounted in it. Like Teecro says, no issues at all!
brianD
#7 Post by brianD » Sat Apr 09, 2016 5:43 am
That's where I wanted to put mine, but was concerned about the 'lift' for the fuel pump. Looks like it's not going to be an issue!!!
Thanks Bryden24shp!!
b
225 Suzuki 4 stroke
#8 Post by Bryden24shp » Sat Apr 09, 2016 9:25 am
I just looked at the new Manitou and its in the same spot, too.
