Don't go there!
So Dealer messed up. This is on the lowest hole. Four below it 3/4" adjustments between the holes. The upper vent plate is 2-1/4 below the transom. To make it level with the transom is hole four. Should I go to five all the way up and and back down?
Dealer says he owes me an adjustment.
Lest you jump and say go even. I can flood the back of my pontoon with a little uptrim and if I open the gate create a foot bath like not tomorrow about 3-4' a half inch deep inside the gate.
Max RPM is 4800 to 4900 at 22-23 MPH GPS, loaded with 6-7 people, two ice chest, kitchen sink etc. I was getting 27 MPH lightly loaded and cleaned up. Prop is a SS 15X15. Rest of the boat stats are in my signature.
WHICH HOLE
- DSwatloski
WHICH HOLE
- 20160421_174634 (360x640).jpg (187.32 KiB) Viewed 2235 times
- 20160421_174639 (360x640).jpg (162.08 KiB) Viewed 2235 times
Dave Swatloski, Northern, VA Lake Anna
2015 Harris 220 CWX - 2015 Mercury 4-Stroke 115 HP Command Thrust, Road King Tandem Axle/w disc brakes
Former 2003 Seapro CC, Yamaha 115 HP 4-Stroke
Former 1990 SunTracker Party Barge 24' Tracker 90 HP 2-Stroke
Re: WHICH HOLE
Hope you get a helpful reply. For a second I thought this post was in the nhb section and I was afraid to open it...
Pinawa Bay, Manitoba
- DSwatloski
Re: WHICH HOLE
Too funny. Me too.
- NonHyphenAmerican
Re: WHICH HOLE
Now just where did you think we'd go with this?Don't go there!
Seriously, I'd think that at least hole 4 would be good.
Re: WHICH HOLE
I think only you, and no one else, can determine which hole produces the best results....uh oh, did I just type that?
Re: WHICH HOLE
The yellow arrow is pointing to what's likely creating the back-splashing problem and also some speed and efficiency loss also.
The green arrow is pointing the target area you need to raise it to, to more or less match the bottom of your transom.
- DSwatloski
Re: WHICH HOLE
Based on the location of the green arrow, I should be at hole five... as high as it can go.Bamby wrote: The yellow arrow is pointing to what's likely creating the back-splashing problem and also some speed and efficiency loss also.
Going to have to ponder that one.
