Towing Set up???
sharky300
Towing Set up???
#1 Post by sharky300 » Fri Apr 29, 2016 9:36 am
Hi all- Weather is breaking here and the itch is on!!!! Ready to get on the water!!!
For those of you who do skiing and tubing... what kind of set up do you have for tow rope. Right now, I just have mine attached to a D ring off to one side of the rear platform. I would like to get something more centered up, and possibly up in the air a bit... Rope drags in the water real bad now. I have seen some things on line, but they are $500.00
May have to dish out the money, but was hoping some of you had engineered some more economical solutions!!!
Thanks-
Jason
Whitehorse
Re: Towing Set up???
#2 Post by Whitehorse » Fri Apr 29, 2016 10:11 am
http://www.amazon.com/gp/product/B001MW ... 4WV220R5R6
Have you looked at stuff like that?
And you could use one of these http://www.amazon.com/SPORTSSTUFF-53-20 ... rope+float to keep the line out of the water.
2001 Suntracker Party Barge 21
90hp 2 Stroke Merc
Figuring it out as we go!
#3 Post by curtiscapk » Fri Apr 29, 2016 11:27 am
Mine was already on THE FLOATER when we got it. a local weld shop should take care of you cheaper.
tow bar measured.jpg (183.19 KiB) Viewed 4153 times
SamiGuy
#4 Post by SamiGuy » Fri Apr 29, 2016 7:34 pm
Walmart has the same harness for less than $20. I had it shipped to store and got it in 3 days.
Hope that helps.
Sami
#5 Post by Bryden24shp » Sat Apr 30, 2016 2:05 pm
I tied to the ex wifes ankle. Worked great!
teecro
#6 Post by teecro » Sat Apr 30, 2016 3:04 pm
Rolled my own from alum handrail fitting and pipe all found in the http://www.mcmaster.com catalog delivered to the house and built with common hand tools; no welding... It is tested and it is strong.... Used 6" x 6" x 1/4" alum plates under the decking at the bolt down points to spread out the load... Investment was at best 250.00
tow bar.jpg (126.88 KiB) Viewed 3958 times
clean and wet.jpg (122.48 KiB) Viewed 3958 times
sharky300
#7 Post by sharky300 » Mon May 02, 2016 1:45 pm
Thanks to everyone for all of the input...
I am looking for ore of what curtiscapk. and teecro have. Mine is set up more like "The FLoater" With the enclosure over the engine. So room is tight.... teecro, I would have never guessed that was not "store bought"- that looks awesome!!!!
Definitely gives me good ideas on how to get er done!!! - I will post some pic's of the results!
Thanks again!!!
Jason
kryptonite
#8 Post by kryptonite » Tue May 03, 2016 10:19 am
Here is the one I made. I made a mock up of it with wood first to get all the angles figured out. Then I welded it up.
sharky300
#9 Post by sharky300 » Tue May 03, 2016 2:31 pm
kryptonite- That is sweet!!! Exactly what I need-
Thanks for the pics!!!
Jason
PlaynDoc
#10 Post by PlaynDoc » Thu May 05, 2016 3:49 am
