Subwoofer location
Rockymountainhigh
Subwoofer location
Any thoughts on where to install the sub? Or maybe more importantly, where not to?
1998 Godfrey Aqua Patio 24'
190 hp I/O V-6 Mercruiser
Re: Subwoofer location
It would be where you have the room. It depends on the size of subwoofer as well as well as where it will fit. Are you looking to build an enclosure or mount the speaker in an existing location? Keep in mind an amp will need to be mounted to power it as well so it will need room also.
I've seen people mount a sub under the steering console or under a seat if there is room. Main thing is when you select a location, you want to keep it away from the elements.
~Mark
~Mark
Mine is under the starboard console. Booms right through it.
Rockymountainhigh
I'm thinking of sticking it in this dead space frame on the left that houses the gas tank. I'm wondering if it will rattle the hell out of my fencing?
- pB4VaL.jpg (114.89 KiB) Viewed 3828 times
I made an enclosure using the outside walls (fence) of the toon. It does in fact make it rattle. It sounds like a loose license plate frame on a Honda Civic with a sub.
- Finish 2.jpg (353.26 KiB) Viewed 3817 times
- 20150503_164704.jpg (370.98 KiB) Viewed 3816 times
I mounted this 10" Kenwood subwoofer in the front of my console. I bought the largest, thickest plastic (?) cutting board I could find (Starboard may have been better but I didn't have a source) then glued it inside the console with 3M 5200 to stiffen the Fiberglass and hopefully dampen the vibrations. I mounted the speaker thru the console and backing and then mounted the amplifier inside the console.
- image.jpeg (56.33 KiB) Viewed 3767 times
- rancherlee
is that the Kenwood that comes with a small Class D amp? I've been looking at adding one of those to my setup.
Yes, the P-WD250MRWrancherlee wrote:is that the Kenwood that comes with a small Class D amp? I've been looking at adding one of those to my setup.
