Getting my Toons wrapped today
Re: Getting my Toons wrapped today
they look AWESOME !!!!!!!!!!! $1080 ? not too pricey......
[b][color=#000000]2011 South Bay 520CR
115 Mercury 4-stroke
Dover, TN
[/color][color=#0000FF]Life is good in God's country![/color][/b]
Dover, TN
Here it is- hope this helps the wrap goes over the nose cone seam
There is one seam up by the nose cone. I feel it will
Be easy to fix if I damage the wrap
Its unbelievable the way these turned out low
Up keep unless u damage
Plus I'm putting on the rubber pontoon bumpers on the
Front of each cone.
Front of each cone.
- image.jpeg (23.2 KiB) Viewed 6518 times
[color=#0040FF]2014 Southbay 22 footer
Keep in water all year
Lake Jacomo
Restricted lake 40hp max
Wrapped toons[/color]
[color=#0000FF]2015 GMC Yukon Denail[/color]
Lake Jacomo
So far so good on the wrap- it's not coming up anywhere - so far very happy with the duribilty and look -
Lake Jacomo
Lake Jacomo
How long has it been in the water so far? Awesome idea hope it works out well, probably a smoother surface than the aluminum anyways?jwachevy wrote:So far so good on the wrap- it's not coming up anywhere - so far very happy with the duribilty and look -
It's been in the water 2 months. No signs of trouble so far!!!
Even if it takes some work to replace its really no more work than
Cleaning the toons with acid wash a few times a year, plus they look
1000 % better than the look we all get after it's been in the water for
Some time - it's just tuff to get them and keep them looking good.
Lake Jacomo
Lake Jacomo
- OldePharte
So where ya goin' ta be?Bryden24shp wrote:Yep. A lift in a covered slip is the only way to go. They can be found really cheap around LotO, too. BTW, we will be down at Lake of the Ozarks the week of July 4th, to demo our Manitou that Denise and I helped design and begged for them to build!
Going to be staying at Heron Bay, in Osage Beach. Same complex we used to own our condo in. PM me with your cell#, we should try to get several of us together! Would be fun!OldePharte wrote:So where ya goin' ta be?Bryden24shp wrote:Yep. A lift in a covered slip is the only way to go. They can be found really cheap around LotO, too. BTW, we will be down at Lake of the Ozarks the week of July 4th, to demo our Manitou that Denise and I helped design and begged for them to build!
Hijacked post
Lake Jacomo
Lake Jacomo
Ya...... Sorry Buddy!jwachevy wrote:Hijacked post
It's ok !!!
Lake Jacomo
Lake Jacomo
I have been asked about the wrap I put on my toons so far ?? It's been in the lake
For 4 months and all is well no peeling no bubbles no damage (so far)
It really makes a difference. I no longer have nasty toons - but!!!!
The real test is when I pull my toon out of the water in November!!!!!
Lake Jacomo
Lake Jacomo
New to this forum, just got my used 2012 Premier 221 Gemini 2 weeks ago.
Did you use the vantage Pontoon protection 3M?
http://www.vantageprotectionproducts.com/pontoon-guard
I have been looking at this to dress up the ugly toons.
Already cleaned them once with toon bright (bass pro), just wasted my money.
No that is like a door edge guard - I used a thin wrap like they use to wrap cars /trucks
They use it as advertising on the sides of vans and cars - when I'm done I peel off
Lake Jacomo
Lake Jacomo
