Triton pontoon separating
[img][img][/img][/img]
Has anyone seen the center pontoon on a HARRIS floteboat separate about an inch---- 3 to 4 ' in from the motor ? Suggestions noticed it while swimming while Under boat lift
- image.jpeg (1.51 MiB) Viewed 4165 times
Re: Triton pontoon separating
Never seen it. But have noticed more online leaking complaints on Harris toons than all the other brands combined.
They're too large a pontoon manufacturer to have such problems.
I wish I could check mine and compare it to yours, but I left my Harris at the marina. We're going back on a week or so. What model and length is yours?
Sorry for typos: should say tritoon-
Boat is a HARRIS 240 sun liner 2007
have you contacted Harris? That's a pretty serious issue!
2007, 2570 Crest LE II
Yamaha F150
Yamaha F150
Is that the center toon I am looking at? How does it seperate in the middle, shouldn't it be welded. This is indeed a serious issue!!! I just don't see how that can even happen. Do you have an pics from farther away showing the damage?
from that 'close up' picture, it looks like the seam was never welded. ????
I can't tell for sure, but that looks like just the riser that mounts the deck to the toon, not the toon itself. If that is the case, then i wouldn't worry about it. That is not a watertight area of the boat construction anyways.
2015 Harris Solstice 220 SL, 150hp Mercury- NEWLY ACQUIRED
2007 BW Montauk 170, 90hp Mercury- For Sale
1974 BW Sourpuss 13', original 40hp Mercury
2011 Sea Doo GTX155
1984 BW Harpoon 4.2- For Sale
Tow Vehicle- 2015 Ford Expedition Limited
2011 Sea Doo GTX155
