Nicked prop. How bad does it look?
Well, brought the father in law on the boat for the first time....he had the bright idea of kicking us away from the dock into shallow gravel bottom water. I tried to kill be engine in time...but nicked the prop. I attached 2 pictures. Is this minimal damage...or prop replacement damage?
Thanks!!!
Thanks!!!
- image.jpeg (49.13 KiB) Viewed 5357 times
- image.jpeg (61.75 KiB) Viewed 5358 times
Re: Nicked prop. How bad does it look?
Mine hasn't looked that good in years.
Use a file and knock the burrs off each blade and you're good to go.
1989 28' Tracker Party Hut
115 hp 4 stroke Yamaha
Sacramento, Ca
Sacramento, Ca
yea a file will fix it fine, it looks all most new to me, wished mine was that nice, no idea how old mine is, i have used it 7 years and it has several small nicks
Great,
Thanks all! I'm new to boating, you all are a great resource!
That's not bad at all... I was expecting a lot worse. Pics came out good...
Yamaha Vmax SHO 115HP
You call that nicked????
lakerunner wrote:You call that nicked????
Haha. Well...now I know it's not bad!
I've sliced tomato's with worse than thatdjmodifyd wrote:Well, brought the father in law on the boat for the first time....he had the bright idea of kicking us away from the dock into shallow gravel bottom water. I tried to kill be engine in time...but nicked the prop. I attached 2 pictures. Is this minimal damage...or prop replacement damage?
Thanks!!!
I wouldnt worry about it... unless you don't like your father in law then I'd bring it up every time I see him
While I was adjusting my transducer I found some bigger nicks. I filed everything down the best I could. Here are pics of the worst nicks
- image.jpeg (64.02 KiB) Viewed 5117 times
- image.jpeg (76.8 KiB) Viewed 5116 times
this is about replacement time
- broken prop.JPG (66.48 KiB) Viewed 5094 times
- rancherlee
That's why I run a 4 blade, when it gets that bad I figure I still have about 3 blades worth of prop left!
x2!lakerunner wrote:You call that nicked????
Those aren't nicks, those blades are ALL Boogered UPMH Hawker wrote:this is about replacement time
Sacramento, Ca
Sacramento, Ca
Hawker,
I nearly spit up iced tea when I saw your prop
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
Lake Conroe, Texas
2006 Yamaha F225
