Add-on double bimini (after market?)
CajunCoach23
#1 Post by CajunCoach23 » Mon Jul 18, 2016 6:03 am
Hi.
We have a Coach 23c with the single bimini and would like to "add" the additional front bimini. The dealer only sells the double as a complete unit and would not give any credit for accepting the single bimini.
Question to the group - do you have any knowledge of attaching a single front bimini to an existing rear single bimini?
2016 Coach 23C
2016 Honda 150
Re: Add-on double bimini (after market?)
#2 Post by curtiscapk » Mon Jul 18, 2016 6:52 am
teecro
#3 Post by teecro » Mon Jul 18, 2016 7:46 am
To be honest there is no real need to connect the 2nd bimini to the first. I'm very happy with the 2nd top that I got for our toon from www.topmastermarine.com I simply adjusted the angle so that one top overlaps the other by a little bit. We can open the 2nd top in just moments or close it as weather/sun dictate....
fwd rad.jpg (91.78 KiB) Viewed 4285 times
Gonefishing
#4 Post by Gonefishing » Mon Jul 18, 2016 9:25 am
Very easily done. I did it and had no problem.
Bob Jacksonville, Nc
2013 Excursion X23 RFC
2013 115 Yamaha
Pulled with a Ford King Ranch
CajunCoach23
#5 Post by CajunCoach23 » Mon Jul 18, 2016 3:05 pm
Gonefishing wrote:Very easily done. I did it and had no problem.
Thanks for reply but which top are you referring to...the previous poster?
Thanks!
2016 Coach 23C
2016 Honda 150
teecro
#6 Post by teecro » Mon Jul 18, 2016 4:44 pm
CajunCoach23 wrote: Thanks for reply but which top are you referring to...the previous poster?
Try searching past threads on the subject such as this one viewtopic.php?f=2&t=20841&hilit=bimini
Having the two tops connected will most likely require a visit to a local shop to alter them so as to zip together.
Keep in mind how you intend to use; if you insist on having the 2 tops connected you may not be able to use one or the other as conditions my dictate. As I have 2 separate tops I can open or close which ever one I so choose.
Another factor is cost and what your willing to spend, a 2nd top can be added for 4 to 5 hundred while a full double can be well double in price....
Cowracer
#7 Post by Cowracer » Wed Jul 20, 2016 7:58 pm
Here is the thread where i did my install for a second top. It has worked out extremely well.
viewtopic.php?f=2&t=21540&p=178614&hilit=bimini#p178614
Tim
CajunCoach23
#8 Post by CajunCoach23 » Thu Jul 21, 2016 6:01 am
Cowracer wrote:Here is the thread where i did my install for a second top. It has worked out extremely well.
Tim
WOW...very nice looking and also some very handy work! I will definitely refer to your thread if we decide to go double!
Thanks!
Mitch
2016 Coach 23C
2016 Honda 150
