Hi all.
I think I've seen flag poles that mount inside/to the mast light (white light). I would like to fly an American Flag, but am curious if the mast light is strong enough to support the additional drag that a flag would create.
Thanks!
Flag pole in mast light..safe?
CajunCoach23
2016 Coach 23C
2016 Honda 150
2016 Honda 150
Re: Flag pole in mast light..safe?
I've been using the Anchor / Nav light pole with clips for our American flag since day 1 with this boat. So far, it's help up perfectly. The flag is about 12" X 16" or whatever the standard small size is. We've run the boat wide open ( 42 MPH ) to out run a thunderstorm a couple of times and both the flag and the pole are fine. The light pole is a thin aluminum tube and has an adjustment knob to allow it to be raised or lowered.
I use "TAYLOR MADE" Charlevoix Flag Clips to attach the flag to the aluminum light pole.
- 1202969.jpg (228.09 KiB) Viewed 4707 times
"Strake"
Richard and Angie
Smith Mountain Lake, VA
2015 Berkshire 233 RFX STS
Yamaha F200 LB
Richard and Angie
Yamaha F200 LB
CajunCoach23
Thanks for reply! Do you know model number, and/or retailer?Strake wrote:I've been using the Anchor / Nav light pole with clips for our American flag since day 1 with this boat. So far, it's help up perfectly. The flag is about 12" X 16" or whatever the standard small size is. We've run the boat wide open ( 42 MPH ) to out run a thunderstorm a couple of times and both the flag and the pole are fine. The light pole is a thin aluminum tube and has an adjustment knob to allow it to be raised or lowered.
Thanks!
2016 Coach 23C
2016 Honda 150
2016 Honda 150
West Marine:
http://www.westmarine.com/buy/taylor-ma ... 14_005_509
Be sure you know the correct diameter of your aluminum light pole...... they make 2 sizes
"Strake"
Richard and Angie
Yamaha F200 LB
Richard and Angie
Yamaha F200 LB
I just put the exact same thing on mine. Works great.
2015 90 HP Yamaha
2017 4WD GMC Canyon
2015 90 HP Yamaha
2017 4WD GMC Canyon
I too, use same flag clips.. but, what I did, was to wrap a few layers of black electrical tape around light pole, before putting on the flag holder... that seems to make the flag clips "dig" into the tape a bit, reducing sliding, without damage to flag pole.
I've got the same Taylor clips from West. They worked just fine until I didn't take my flag down when I left the marina and let Old Glory flap away during a hellacious storm. The stress didn't help my anchor light mast. Loose at the base and it wiggles. Screws could never get it tight enough.
So, I got tired of the wiggly anchor light mast and I kneeded up some epoxy putty and set it around the base. It won't come off now, but it won't wiggle either. The screw/pivot still drops the mast and I use a small bungee on it when trailering.
