Gauges not working
Gauges not working
The gauges which read engine info (tachometer, hour meter, trim) are not working. The tachometer and trim gauges respond to the initialization when key is turned on but nothing after. I assume it's a signal issue and not a fuse since they do the initialization. They are Faria analog gauges connected to a Mercury Verado 150. Any ideas where to start troubleshooting?
2006 Harris Super Sunliner 240, 2006 Mercury Verado 150
"I'm back to living Floridays, blue skies and ultraviolet rays..."
-Jimmy Buffett
-Jimmy Buffett
Re: Gauges not working
If they're all analogue gauges, and this fault is common across all the gauges it may be a bad ground.
Not sure how they are connected to though. Did you get a wiring diagram with the boat or motor?
definitely crawl under the helm and wiggle some wires. Especially the ground wires coming from gauge cluster.
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
Lake Conroe, Texas
2006 Yamaha F225
try this.
- InstrumentPanelWiring.jpg (46.64 KiB) Viewed 4161 times
