My boat's PO mounted the locator transducer on the (R) keel rib.
It does work but is vulnerable to bumping, dragging and trailer damage. How can I mount it better when there's no bracket provided?
MUST be a better way to mount a transducer...
- bracket.jpg (302.37 KiB) Viewed 2899 times
Mark
Rush Lake, Atlanta, MI
Re: MUST be a better way to mount a transducer...
I'm surprised that even works. Have a proper bracket welded to the Starboard pontoon.
you can make your own bracket
- bracket.JPG (1.43 MiB) Viewed 2838 times
Re: guy48065
[quote="guy48065"]I bought a glue-on plastic mounting block at Bass Pro... Is that any good?
Welding really not an option out in BFE .[/quote]
Atlanta MI is not BFE but that was my 2nd thought of using JB-Weld 24-Hour Epoxy on well cleaned and abraded alum to a block of plastic also abraded...
