Harris 280 cosole butons
skip15
#1 Post by skip15 » Sun Jan 08, 2017 12:59 pm
does anyone no where i can find the layout of the console buttons on a 1991 this is what the buttons look like but i can't read wha they say
MH Hawker
Re: Harris 280 cosole butons
#2 Post by MH Hawker » Sun Jan 08, 2017 3:18 pm
more than likely you will have to make them your self new switches and some pvc stick on names or a lot of trophy shops can make a plates with names in plastic or brass
sprintfan
#3 Post by sprintfan » Mon Jan 09, 2017 7:26 am
I believe acc stands for accessory as in extra to add something to. might have to follow wire from back of switch or check if it is even used. on mine one was used for the livewell pump and another was for the fishfinder.
Drago
#4 Post by Drago » Thu Jan 12, 2017 10:31 am
I think what you are not able to read/see is the amp rating of that circuit for that fuse/switch. Not sure where you might find the panel layout but replacements are to be found at....
https://www.jamestowndistributors.com/u ... ush+Button
What you would need to determine is what device those fuse/switch combos control so you can size the amp rating correctly. I'll bet most are not labelled with amp rating. Mine are not. I suspect most are 15.
You might also consider looking for a panel to replace the full collection....
http://www.iboats.com/Marine-Switch-Pan ... _id.216629
or
https://www.amazon.com/Waterproof-Rocke ... B00DR5JBM8
or something you can set your own fuse size...
http://www.overtons.com/modperl/product ... el&i=71706
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
mpilot
#5 Post by mpilot » Thu Jan 12, 2017 2:47 pm
That looks like a circuit breaker to me and not a switch. I have them on my boat below each switch instead of a fuse block.
PlaynDoc
#6 Post by PlaynDoc » Thu Jan 12, 2017 5:23 pm
[quote="mpilot"]That looks like a circuit breaker to me and not a switch. I have them on my boat below each switch instead of a fuse block.[/quote]
agree. circuit breaker for accessory
