Fuel Supply Module
taylorjm
Fuel Supply Module
#1 Post by taylorjm » Tue Apr 18, 2017 11:39 am
Anybody open up the fuel supply module on a 90/115hp 4 stroke? Mine is a 2007 and I was reading that there's a small hose inside the module that deteriorates from ethanol, so I ordered a new one and was going to be proactive and replace it. There's a lower bolt holding the fsm on that I can't get to! Maybe I have to remove the lower cowling? I was hoping to not have to remove the fsm completely but pull it out and open it up.
Re: Fuel Supply Module
#2 Post by lakerunner » Tue Apr 18, 2017 7:40 pm
What motor do you have?
taylorjm
#3 Post by taylorjm » Wed Apr 19, 2017 7:22 am
[quote="lakerunner"]What motor do you have?[/quote]
2007 Mercury 4 stroke 90hp. Sorry, missed the mercury part.
FLOUNDERPOUNDER225
#4 Post by FLOUNDERPOUNDER225 » Wed Apr 19, 2017 9:35 am
Mercury calls it a Module, other's are referred to as a VST Vapor Separation Tank, Ethanol is a killer, for some reason the mercury fuel pumps inside just get destroyed from the water that collects due to ethanol and long storage. Here is the last one I worked on, you can see the "hose" you are referring to, the black one. This pump was completely seized and had to be replaced. DON NOT Use ethanol fuel..
vst pump.jpg (234.98 KiB) Viewed 2917 times
Pensacola FL
2015 Berkshire 231 RFC
Yamaha F-150
taylorjm
#5 Post by taylorjm » Wed Apr 19, 2017 9:49 am
I wish that was an option. I've never seen anywhere within an hour from me that has 100% gasoline. Also mine is plastic and in a spot I can't seem to remove the lower bolt without removing the entire lower cowl, which means the steering cable too I think.
Actually, I did find an option that's just past where I exit to go to my lakehouse. So I may be able to get the gas cans and try it.
FLOUNDERPOUNDER225
#6 Post by FLOUNDERPOUNDER225 » Thu Apr 27, 2017 7:07 am
Have you ever used this website?
http://www.pure-gas.org/index.jsp?stateprov=MI
Everyone who has a boat should use this.
Saginaw UNBRANDED 87 90 Gratiot Express Stop 989-781-4171 7015 Gratiot Rd 2017-01-09
Pensacola FL
Yamaha F-150
taylorjm
#7 Post by taylorjm » Thu Apr 27, 2017 9:40 am
Huh, that's about 2 miles from my house, and I go by there at least 4x a day. I'll have to check that one out. They were just rebranded with bp gas a few months ago, maybe they added it, or removed it. Thanks!
