Go figure this out
Go figure this out
We have a 2007 Suntracker w/ Merc 60 Bigfoot that we bought new.
For the last 9 yrs., the best this setup would run was 5,000 rpms and 15 mph.
Took it out yesterday, for the first time this year, and am running 17mph@6,000rpms.
This was under normal conditions with 2 adults and 1/2 tank of gas.
The boat has been hanging in the lift since last October and has not been touched.
I think I'll hang it back until next year and maybe hit 20mph.
LOL....all this is true, but I'm not really hanging it up for a year.
SMLTOONER
Ted & Emily
2019 Bennington 21SL Tri-toon
2019 Yamaha 150 HP
Smith Mtn. Lake, Virginia
Ted & Emily
2019 Yamaha 150 HP
Re: Go figure this out
This sure is an amazing election year !!!
You've gotta be happy !
Yamaha Vmax SHO 115HP
somebody wanted your prop so they sneeked in and changed it out so you wouldnt notice right away.
The prop changing theory is good too!
We started out last year, in cooler spring temps (cooler than summer, anyways), running ~5750RPM and maybe 21MPH with our 70HP 2 stroke. At some point during last summer, WOT was no more than 5250RPM and 20MPH. I assumed it was growth on the bottom of the toons as I was 'warned' about this (from a shop that cleans tunes). Life went on...
Then last fall, without any cleaning of the toons, our RPM increased and back to 21 MPH max.
I now believe the air temperature was the reason for the changes. I can't think of anything else to cause this. If so, would this show up more on a 2 stroke compared to a 4 stroke? I dunno.
Paul
There's more oxygen in colder air than hot air. Boats are usually faster in Spring and Fall than in the heat of the Summer. A couple of mph difference may be normal.
The temp was 84, so I consider that a summer time temp.
I like the prop thief theory.
SMLTOONER
Ted & Emily
2019 Yamaha 150 HP
Ted & Emily
2019 Yamaha 150 HP
Strong tailwind?
Ted,
I'm going with the OLD FUEL theory !
We had our toon our on the lake yesterday, and again today for a few hours. Noted to friends, that I'm still running on last November's last fuel up. Have put on about 12 hours of use since last filling up in November. Our tank holds 52 gallons so I'll be getting fresh fuel next time out or so.......
Richard
Richard
"Strake"
Richard and Angie
Smith Mountain Lake, VA
2015 Berkshire 233 RFX STS
Yamaha F200 LB
Richard and Angie
Yamaha F200 LB
What about the clean toons theory? All the gunk/crud/growth dried up and fell off during winter lay up.
Strake.....how would OLD FUEL make it run better? I was running on last year's gas.
BobL.....when my 'toon is not being used it is hanging in the lift, so there is no growth, to speak of, on the logs. I do like the idea though.
crspang.....not much wind that day and it was consistently better no matter the direction.
SMLTOONER
Ted & Emily
2019 Yamaha 150 HP
Ted & Emily
2019 Yamaha 150 HP
If it truly gained 1,000 rpm's, I agree that someone had to change the prop.
Old gas would hurt RPM's
A tail wind would not gain rpm's more the 50-100.
I think its the EzFenders! They work magic...
[quote="smltooner"]Strake.....how would OLD FUEL make it run better? I was running on last year's gas.[/quote]
only jesting.....
only jesting.....
"Strake"
Richard and Angie
Yamaha F200 LB
Richard and Angie
Yamaha F200 LB
It is well know in the boating industry that if your boat sits up high off the ground or water for a while, all your horsepower will start to settle to the bottom of your outdrive. Your first time taking the boat out, you will have more than normal horsepower at the prop. I don't think you will have much more left for your second time out, let us know.
2014 Bennington 2375 RCW with Verado 250 Pro and Simon Motorsports ECM upgrade to 325 HP
Tri Toon with ESP package
