Hey everyone.
Hit a rock with the prop this weekend, gouged the blades up enough that i ordered a replacement. Was concerned about vibration. How much damage is generally repairable I'm wondering? Thanks in advance.
Prop repair, is it worth it?
Tim in Michigan
2014 Bennington 2375 GCW
90 Mercury
90 Mercury
Re: Prop repair, is it worth it?
A good shop can fabricate a new blade. Most just need to be filled in and balanced.
I used to go thru an aluminum prop every year. Fortunately the prop shop owner was a cousin.
After going to a stainless prop, I never ruined another prop.
A good prop shop can remanufacture a prop just fine.
If you are not comfortable running a repaired prop, you can buy a new one and keep the repaired one as a back-up in case something happens to the new one.
2015 90 HP Yamaha
2017 4WD GMC Canyon
2015 90 HP Yamaha
2017 4WD GMC Canyon
had mine repaired... 80 bucks or so, if i recall....
the repair shop is 2 hours away, but since i had to make a run in that direction anyway, just dropped it off... when they finished they mailed it back to me, for about $20 more...
yep, i spent 100 bucks on repairing my beat up propeller...... but they did a great job. looked brand new
